嗨,
我使用的是Spartan 3E Xilinx入门板。 我想知道它是否可以产生1.8V输出? 我们如何指定输出电压? 问候, AMAN 以上来自于谷歌翻译 以下为原文 Hi, I am using Spartan 3E Xilinx starter board. I want to know whether it can generate 1.8V output ? And how can we specify the output voltage level ? Regards, AMAN |
3个回答
输出电平由施加到I / O单元的电压电平定义。
如果Spartan-3E板上的VCCO不是1.8V,则不会得到0-1.8V输出信号,而是获得0-VCCO输出信号(LVDS是此规则的一个例外)。 为了改变这种情况,您必须更换Spartan-3E板上的VCCO电源。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 The output level is defined by the voltage level that is applied to the I/O cells. If the VCCO on the Spartan-3E board is not 1.8V then you will not get a 0-1.8V output signal and instead you will get 0-VCCO output signal (LVDS is an exception to this rule). In order to change this you would have to change the VCCO power supply on the Spartan-3E board. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.comView solution in original post |
如果Spartan-3E板上的VCCO不是1.8V,则不会得到0-1.8V输出信号,而是获得0-VCCO输出信号(LVDS是此规则的一个例外)。 为了改变这种情况,您必须更换Spartan-3E板上的VCCO电源。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 The output level is defined by the voltage level that is applied to the I/O cells. If the VCCO on the Spartan-3E board is not 1.8V then you will not get a 0-1.8V output signal and instead you will get 0-VCCO output signal (LVDS is an exception to this rule). In order to change this you would have to change the VCCO power supply on the Spartan-3E board. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
嗨,
检查原理图我没有看到任何1.8V VCCO连接到任何组。 没有一个电压调节器输出1.8V电平信号-http://www.xilinx.com/support/documentation/boards_and_kits/S3E_Starter_Schematic.pdf。 检查第5页 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Checking the schematics i do not see any 1.8V VCCO connected to any of the banks. None of the voltage regulators output a 1.8V level signals - http://www.xilinx.com/support/documentation/boards_and_kits/S3E_Starter_Schematic.pdf. Check Pg 5 Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2078 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2193 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
423浏览 1评论
1523浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
508浏览 0评论
1638浏览 0评论
GMT+8, 2024-4-24 05:32 , Processed in 0.941224 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
