发 帖
原厂入驻New
[问答] vivado中自定义IP应用
4448 vivado FPGA
分享
现在我在Vivado中做了一个基于axi总线测量频率的ip核,不知道在sdk中怎么读出频率计数值,
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 2019/07/20 11:04:26
// Design Name:
// Module Name: meas_freq
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module meas_freq(
        input                        clk_100M,        //100MHz系统时钟
    input            square  ,
    output wire [27:0]   CNTCLK,        //闸门内系统时钟周期计数
    output  wire  [27:0]  CNTSQU   //闸门内待测方波时钟周期计数
    parameter   GATE_TIME = 28'd99_999_999;//实际闸门计数是99_999_999,仿真时设为10ms
    reg        square_r0 = 1'b0;
    reg        square_r1 = 1'b0;
    reg        square_r2 = 1'b0;
    reg        square_r3 = 1'b0;
    reg [27:0]    cnt1 = 28'd0;   //产生 1s 的闸门信号的计数器
    reg        gate = 1'b0;    //闸门信号
    reg        gatebuf = 1'b0; //与方波同步之后的闸门信号
    reg        gatebuf1 = 1'b0;//同步闸门信号延时一拍
    reg    [27:0]    cnt2 = 28'd0;
  reg    [27:0]    cnt2_r = 28'd0;
    reg    [27:0]    cnt3 = 28'd0;
  reg    [27:0]    cnt3_r = 28'd0;
  //   reg   [27:0]   CNTCLK= 28'd0;
//   reg    [27:0]   CNTSQU= 28'd0;
    wire        square_pose,square_nege;
    wire        gate_start,gate_end;
    //使方波和100MHz时钟同步并捕捉待测方波的边沿
    always @ (posedge clk_100M)
    begin
        square_r0 <= square;
        square_r1 <= square_r0;//将外部输入的方波打两拍
        square_r2 <= square_r1;
        square_r3 <= square_r2;
    end
    assign square_pose = square_r2 & ~square_r3;
    assign square_nege = ~square_r2 & square_r3;
    begin
        IF(cnt1 == GATE_TIME)begin
            cnt1 <= 28'd0;
            gate <= ~gate;//产生 1s 的闸门信号
            end
        else begin
            cnt1 <= cnt1 + 1'b1;
            end
    end
    always @ (posedge clk_100M )
    begin
        if(square_pose == 1'b1)begin
            gatebuf <= gate;//使闸门信号与待测方波同步,保证一个闸门包含整数个方波周期
            end
        gatebuf1 <= gatebuf;//将同步之后的闸门信号打一拍,用于捕捉闸门信号的边沿
    end
    assign    gate_start = gatebuf & ~gatebuf1;//表示闸门开始时刻
    assign    gate_end = ~gatebuf & gatebuf1;//闸门结束时刻
    //计数系统时钟周期
    begin
        if(gate_start == 1'b1)begin
            cnt2 <= 28'd1;
            end
        else if(gate_end == 1'b1)begin
            cnt2_r <= cnt2;//将所得结果保存在cnt2_r中,并将计数器清零
            cnt2 <= 28'd0;
            end
        else if(gatebuf1 == 1'b1)begin//在闸门内计数系统时钟周期
            cnt2 <= cnt2 + 1'b1;end
    end
    //计数待测方波周期数
    begin
            cnt3 <= 28'd0;
            end
            cnt3_r <= cnt3;//将所得结果保存在cnt3_r中,并将计数器清零
            cnt3 <= 28'd0;
            end
        else if(gatebuf1 == 1'b1 && square_nege == 1'b1)begin//在闸门内计数待测方波周期数(数闸门内方波的下降沿)
            cnt3 <= cnt3 + 1'b1;
            end
    end
  assign CNTCLK = cnt2_r;
  assign CNTSQU = cnt3_r;
endmodule
2019-7-22 17:16:26   评论 分享淘帖 邀请回答
相关问题
1个回答
你这个有闸门信号的应该是等精度测频法吧 可以去查下有关资料
2019-7-22 17:53:29 1 评论
举报
1 条评论
  • 2019-7-22 19:05
    对是等精度的测量方法,然后做好的ip在调用的时候没有对应的频率出来不知道怎么在sdk里输出
撰写答案
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
我要提问
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
