我看了应用说明AN52478的CY8CPLC10。我正在开发一个带有CY8CPLC20的项目,它的外部主机SAMD20来自Atmel。在PLCI I2C中具有低电平的功能,如PLCL I2CYSTART和PLC中的PLCI接口等高电平。
当我选择PLS20的FSK+网络+I2C选项时,有有限的功能可供我使用,例如PLC启动和PLC轮询。由于资源已经存在,我无法添加类似于您的应用程序中的一个硬件I2C块。如果我选择在PLC20中给出的I2C,我只能访问有限的函数。 你能指导我开发一下这个软件吗?我想开发应用程序,使ATMEL能够在更高的水平上控制PLC。我需要能够向PLC发送命令。IE -发送消息,读取消息更改参数等。我能通过选择PLC+Network + I2C来做这件事,或者我应该用HW块来开发它。你能就此提出建议吗? 以上来自于百度翻译 以下为原文 I looked at the application note AN52478 for the cy8cplc10. I am developing a project with cy8cplc20 with an external host samd20 from atmel. There are functions which are available in low level such as PLC_I2C_start in plc_i2c and high level such as PLC_INIT in plc.c. When I choose the FSK+network+ I2C option for the plc20, there are limited functions available to me such as plc start and plc poll. I cant add a hardware i2c block similar to the one in your application since a resource is already present. If I choose the I2C given in the plc20, I can only access limited functions. Could you please guide me on the development of the software. I want to develop the application such that the atmel has control over the plc at higher level. I need to be able to send commands to the plc . i.e- send message, read message change a parameter etc. Would I be able to do this by choosing PLC+network+I2C or should I develop it using a HW block. Could you please advise on this as well. |
2个回答
考虑使用SPI、一条线或UART用于命令接口。
问候,Dana。 以上来自于百度翻译 以下为原文 Consider using SPI, One Wire, or UART for the command interface. Regards, Dana. |
谢谢黛娜,
但是CY8CPLC20有一个内置的I2C接口。我可以读写内存寄存器。我想知道PLT是否有默认配置,所以我可以调用它。 以上来自于百度翻译 以下为原文 Thanks dana, but the cy8cplc20 has a built in i2c to interface with. i can read and write to the memory registers. I wanna know whether theres a default configuration for the PLT so i can call it |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-20 03:09 , Processed in 0.648668 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
