在映射阶段,我得到以下关于数据总线上每个位的三态控制的错误 -
错误:打包:2531 - 双数据速率寄存器“ddr_ab / grp5_cell”无法根据需要加入“OLOGIC2”组件。 寄存器符号ddr_ab / grp5_cell的输出信号需要一般路由到结构,但寄存器只能路由到ILOGIC,IODELAY和IOB。 下面列出的是我的三态控制代码示例 ODDR2 grp5_cell(.Q(ddr_sram_ab_rdata_group5_oel),. C0(sram_clk),. C1(sram_clkinv),. CE(1'b1),. D0(sram_rdata_group5_oel),. D1(sram_rdata_group5_oel),. R(1'b0),. S(1'b0)); IOBUF_LVCMOS25 sram_ab_data0_pad(.O(ddr_sram_ab_rdata [0]),. O(sram_ab_data [0]),. I(ddr_sram_ab_wdata [0]),. T(ddr_sram_ab_rdata_group5_oel)); 我已经阅读了类似于我的消息,但没有看到有关三态控制的信息。 以上来自于谷歌翻译 以下为原文 During the map phase I am getting the following error pertaining to the tri-state control for each of the bits on my data bus - ERROR:Pack:2531 - The dual data rate register "ddr_ab/grp5_cell" failed to join the "OLOGIC2" component as required. The output signal for register symbol ddr_ab/grp5_cell requires general routing to fabric, but the register can only be routed to ILOGIC, IODELAY, and IOB. Listed below is a sample of my code for the tri-state control ODDR2 grp5_cell (.Q(ddr_sram_ab_rdata_group5_oel), .C0(sram_clk), .C1(sram_clkinv), .CE(1'b1), .D0(sram_rdata_group5_oel), .D1(sram_rdata_group5_oel), .R(1'b0), .S(1'b0) ); IOBUF_LVCMOS25 sram_ab_data0_pad (.O(ddr_sram_ab_rdata[0]), .IO(sram_ab_data[0]), .I(ddr_sram_ab_wdata[0]), .T(ddr_sram_ab_rdata_group5_oel)); I have read the messages similar to mine but have not seen on concerning the tri-state control. |
3个回答
问题已经解决。
我的同事向我指出,数据位的每个ODDR都需要ODDR驱动每个位的三态控制。 一旦做出这种改变,合成就会出现问题。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 The issue has been resolved. I co-worker pointed out to me that each ODDR for the data bits needed an ODDR driving the tri-state control for each bit. Once this change was made the synthesis proceeded with problems. View solution in original post |
嗨,
你能打开合成设计(技术原理图)并检查单元“ddr_ab / grp5_cell”输出是如何连接的吗? 您需要确保此DDR的输出单独驱动IOBUF并且不会循环到结构中。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Can you open synthesized design (technology schematic) and check how the cell "ddr_ab/grp5_cell" output is connected? You need to ensure that the output of this DDR drives the IOBUF alone and is not looped in to fabric. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
问题已经解决。
我的同事向我指出,数据位的每个ODDR都需要ODDR驱动每个位的三态控制。 一旦做出这种改变,合成就会出现问题。 以上来自于谷歌翻译 以下为原文 The issue has been resolved. I co-worker pointed out to me that each ODDR for the data bits needed an ODDR driving the tri-state control for each bit. Once this change was made the synthesis proceeded with problems. |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2589 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2062 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1503浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2163浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-28 21:31 , Processed in 1.038576 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
