你好,
我创建了一个USB HID启动项目,一个项目一个bootloadable psoc5。 我的测试bootloadable项目只是一个PWM切换LED。到目前为止,因为一旦我加载Bootloader bootloadable与u***bootloader GUI软件,我松在PC的USB设备和创业板切换LED作为我的配置在bootloadable。 问题是,当我把我的应用程序的一个bootloadable项目然后程序到PSoC采用Bootloader的软件,它似乎做它但进度条永远不会结束。我听到声音,但然后断开USB连接了所以我的软件才开始而是停留在引导。 我没有任何错误。我配置的bootloadable具有相同的依赖,我用我的第一个LED测试bootloadable应用所以我不知道是什么问题。我只使用26.2闪光在我应用32 RAM所以我不认为可能的原因。 是什么原因造成的? 谢谢您。 以上来自于百度翻译 以下为原文 Hi, I have created a USB HID bootloader project and a bootloadable project for a PSoC5. My test bootloadable project is just a PWM which toggles a LED. So far the bootloader works because once I load the bootloadable with the USB bootloader GUI software, I loose the USB device in the PC and the board starts toggling the LED as I configured it in the bootloadable. The problem is that when I convert my application program to a bootloadable project and then program it to the PSoC using the bootloader software, it seems to do it but the progress bar never gets to the end. I hear the u*** sound as disconnecting but then is connected again so my software never starts but instead stays in the bootloader. I don't get any error. I configured the bootloadable with the same dependencies that I used for my first LED test bootloadable application so I don't know what the problem might be. I'm only using 26.2% of Flash and 32.8% of RAM in my application so I don't believe that could be the cause. What could be causing this? Thank you. |
5个回答
这里是引导加载程序的一个PIC
罪恶T?吐鲁番 11.8 K 以上来自于百度翻译 以下为原文 Here is a PIC of the bootloader application
你好,
我不能在这里发布项目,因为是工作。你能告诉我应该检查什么吗? 我试图使项目再次形成0只增加零件和部件检查,每次我添加的应用程序还可以通过编程的程序的一部分代码。 以上来自于百度翻译 以下为原文 Hi, I can't post the project here since is for work. Could you tell me what should I check? I'm trying to make the project again form 0 just adding the parts and the code by parts checking that eveytime I add a part of the application it still can be programmed by bootloader. |
然后你可以在赛普拉斯项目,而不是公共领域,通过
案情审查 提交一个技术案例 CyPress网站 “支持” “技术支持” “创建一个MyCase'” 问候,Dana 以上来自于百度翻译 以下为原文 Then you can post project at Cypress, which is not public domain, by fileing a CASE - To file a tech case - www.cypress.com “Support” “Technical Support” “Create a MyCase” Regards, Dana |
我用蓝牙模块的UART bootloader没有运气。
我已经尝试了USB,但我不能让它工作。 我连最简单的bootloader和bootloadable项目。bootloadable的作品就好如果你删除UART我添加。我知道这是因为LED闪烁的bootloadable应用慢,我也松了USB连接直到我重新启动板。 基本上没有代码,所以我不知道什么问题可以。 我真的很感激任何帮助。 谢谢您。 以上来自于百度翻译 以下为原文 I have had no luck with the UART bootloader using the bluetooth module. I've tried again with the USB but I can't make it work. I've attached the simplest bootloader and bootloadable projects. The bootloadable works just fine if you delete the UART that I've added. I know it works because the LED blinks slower with the bootloadable application and also I loose the USB connection until I reboot the board. There is basically no code so I don't know what the problem can be. I would really appreciate any help. Thank you. |
嗯我在柏树filders更好的搜索,我发现了一个新的引导程序的主程序。
我用过它……该文件被正确地上传到我的PSoC 5项目和工作太。 不管怎样,还是谢谢你! 以上来自于百度翻译 以下为原文 Wel I did a much better search in the Cypress filders and I found a new Bootloader host program. I used it and ...tada.. the file was correctly uploaded to my PSoC 5 project and was working too. Thanks anyway! |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-18 22:21 , Processed in 0.630346 second(s), Total 78, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
