你好,
我刚刚完成的一个程序广泛使用了Co()SN()函数,这使得整个算法在PSoC 5LP上的速度太慢,在67 MHz… 我想知道,UDB能被编程通过硬件来计算这个函数吗?(我正在尝试泰勒/切比多项式,但硬件解决方案将明确地做到这一点!!) 谢谢! 以上来自于百度翻译 以下为原文 Hi, A program I just finished makes extensive use of cos() sin() functions, which makes the whole algorithm way too slow on a PSoC 5LP at 67MHz... I was wondering, could UDB be programmed to calculate this functions somehow via hardware... (I'm in the process of trying Taylor/Cheby polynomials, but a hardware solution would definitevitely do it!! ) THANKS! |
3个回答
CORDIC算法:一种方法
HTTP://E.WiKiTo.Org/Wik/Cordic 那里有UDB ASM和编辑器来构造你自己的 HTTP://www. GoGoLe.COM/URL?SA = T &;RCT= J &;q = &;ESRC = S &;源=网站&;CD = 3,= 0cdcqfjac &;&;URL = HTTP 2f 2fteal 3a % % % % %。GMU。教育2fcourses 2fece645 % % % 2fcordic 2ftalks 2fprojects_s06 PDF &;EI = dk0du5b3hyrkyagsvidqcw &;USG = afqjcnhxm9zwliirjmvsx79rgte_fudxtq &;容量= 61535280,d.dmq BV。 问候,Dana。 以上来自于百度翻译 以下为原文 CORDIC algorithim one approach - http://en.wikipedia.org/wiki/CORDIC The there is alwas UDB asm and editor to construct your own http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CDcQFjAC&url=http%3A%2F%2Fteal.gmu.edu%2Fcourses%2FECE645%2Fprojects_S06%2Ftalks%2FCORDIC.pdf&ei=Dk0DU5b3HYrkyAGsvIDQCw&usg=AFQjCNHxm9zwliIRJmvsx79RGtE_fUdXTQ&bvm=bv.61535280,d.dmQ Regards, Dana. |
另一种方法是使用查找表、大小和元素大小。
当然控制精度。 如果你使用谷歌“嵌入正弦算法”,你会得到一个数字。 对论文、解决方案的点击。 问候,Dana。 以上来自于百度翻译 以下为原文 Another approach is use of a lookup table, size and element size of course controlling accuracy. If you google "embedded sine algorithms" you will get a number of hits on papers, solutions. Regards, Dana. |
谢谢Dana,
我知道用不同的方法来计算罪恶,COS更有效率…我只是不确定哪一个可以被编入UDBs,因为我没有仔细研究它们。我会去看科尔迪克阿尔格。 谢谢您 以上来自于百度翻译 以下为原文 Thanks Dana, I'm aware of the different approaches to calculate a sin, cos more efficiently.... I'm just not sure which one could be programmed into UDBs since I haven't looked into them on detail.... I'll look onto de cordic alg. thank you |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-20 02:16 , Processed in 0.614891 second(s), Total 75, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
