嗨-我想让proteus和MPLABX一起工作。我记得几年前它工作过,但我离开图片一段时间。我已经收到了一个新的PIC项目——我已经安装了MPLABX和Proteus的最新版本,安装了MPLABX Proteus查看器插件,但我不能让它们一起工作。不确定它是MPLABX还是Proteus问题…找不到任何关于它的在线信息。与我的机器之间的一些应用程序间的通信问题?当我尝试调试项目时,消息是“Proteus VSM查看器未找到”。这个项目的最后一个工具是不可用的。“点是灰色的……我记得几年前,它是红色的。我正在使用一个虚拟机(MacBook Pro上的并行桌面),所以我尝试创建一个新的Windows 10虚拟机,并加载了MPLABX、XC8和Proteus的新副本。一个演示版本和一个授权版本进行测试。同样的问题,有人有什么想法吗?任何人都有这个设置运行,或者有可能破坏这个功能吗?谢谢。。。
以上来自于百度翻译 以下为原文 Hi - I'm trying to get Proteus to work with MPLABX. I recall having it working a few years back, but I went away from PICs for a while. I've received a new PIC project -- I've got the latest versions of MPLABX and Proteus and the MPLABX-Proteus Viewer plugin installed, but I can't get them to work together. Not sure if it's a MPLABX or Proteus problem...can't find anything online about it. Some inter-application communication issue with my machine? When I try to debug the project, the message is "Proteus VSM Viewer Not Found. The last tool used for this project is unavailable." The dot is grey...as I recall from a few years back, it used to be red. I'm using a virtual machine (Parallels Desktop on a MacBook Pro) so I tried creating a fresh Windows 10 virtual machine and loaded new copies of MPLABX, xc8 and Proteus (tried both a demonstration version and a licensed version for testing). Same problem. Anybody have any ideas? Anybody have this setup running, or is it possible this functionality is broken? Thanks... Attached Image(s) |
11个回答
如果你是对的,MPLAX X在我眼中更糟糕。这意味着插件接口在MPLAB X和插件本身之间发生了变化。如果第三方软件开发者每次发布一个新版本的MPLAX,都必须做出反应和改变/检查插件,这是不好的。
以上来自于百度翻译 以下为原文 If you are right, the MPLAB X is even worse in my eyes. That means that the plugin interface have changed between MPLAB X and the plugin itself. If 3rd party software developers must react and change/check plugins every time a new version of MPLAB X is released, it's bad... |
是的,这是真的,我花了太多的时间与微芯片工具打交道,尤其是MPLABX。当我需要完成一个没有工具问题的项目时,我仍然回到MPLAB 8.92。在这种情况下,问题可能是MPLABX,也可能是Proteus(插件提供商)。像你一样,我怀疑如果问题报告给任何一方,他们会指责另一方。用户厌倦了这一点,就放弃了。也许这个问题没有在网上被广泛讨论。叹息。我将启动一个支持票,并报告回这个线程对我的成功或缺乏它…
以上来自于百度翻译 以下为原文 Yes, it's true, I spend way too much time fighting with Microchip tools, especially MPLABX. I still revert to MPLAB 8.92 when I need to get a project done without tool hassles. In this case, the problem might be with MPLABX, or it might be with Proteus (the plugin provider). Like you, I suspect that if the problem is reported to either party, they will point their finger at the other one. The users get tired of this and just give up. Probably why this issue isn't discussed much online. Sigh. I will initiate a support ticket and report back to this thread on my success or lack of it... |
好的,我花了周六下午安装了MPLABX的不同版本,并且查看了MPLABX-Proteus功能在哪里中断(多么有趣…)看起来像一个警察队伍;……。结果证明除了最新版本3.35之外,Proteus的所有版本都正常。我在3.35中得到以下错误信息:我卸载并重新安装了3.35……它拒绝工作。无论如何,我很擅长恢复到以前的版本,而不是使用最新的版本。看起来像Microchip(或NETBeBeus)做了一些打破最新版本的Proteus插件。有趣的是,我从来没有在网上看到过这个报道,所以我想再问一次,是否有人成功与Proteus和MPLLABX3.35?如果其他人看到同样的问题,我会给Microchip提供一张支持票。
以上来自于百度翻译 以下为原文 OK, I spent my Saturday afternoon installing different versions of MPLABX and seeing where the MPLABX-Proteus functionality breaks (what fun...) Looks like a police lineup ;).... Turns out ALL VERSIONS WORK with Proteus EXCEPT the latest version, 3.35. I get the following error message with 3.35: I uninstalled and reinstalled 3.35...it refuses to work. Anyway, I'm good with reverting to the previous version instead of using the latest one. Looks like Microchip (or Netbeans) did something to break the Proteus plug-in with the latest version. Funny, I haven't seen this reported anywhere online, so I'd like to ask again if anyone else is having success or not with Proteus and MPLABX 3.35? If others are seeing the same issue, I'll file a support ticket with Microchip. |
如果你想发疯的话,有3.25和3.26。希望你能在星期一收到乔治的来信。
以上来自于百度翻译 以下为原文 There is a 3.25 and 3.26 if you want to go crazy. Hopefully you will hear from George on Monday. |
嗨,我在MPLAB X v3.40中也遇到过同样的问题,但是它在v3.30中运行良好。这可能是Proteus插件和新的MPLLABXv3.40之间的兼容性问题,我通过票据报告了这一点。
以上来自于百度翻译 以下为原文 Hi, I experienced the same issue with MPLAB X v3.40 but it works fine with v3.30. It could be a compatibility issue between Proteus plugin and the new MPLAB X v3.40 I reported this through a ticket. Regards |
对于那些猜错了手指的人来说,这是错误的。我们这里有一个沟通的失败。变形金刚的用户找到乔治的联系人。
以上来自于百度翻译 以下为原文 For those who guessed finger pointing, wrong. What we have here is a failure to communicate. Proteus users find the George the contact. |
虚拟电路板VBB-X插件和PICsimlab mplabx插件也存在同样的问题,Mplab-X插件API在3.35中明显发生了变化,但是SDK的文档没有变化。
以上来自于百度翻译 以下为原文 There are the same problem with virtual breadboard VBB-X plugin and PICsimlab mplabx plugin. Mplab-X plugin API apparently has changed in the 3.35 but the documentation of SDK don't. |
既然有人从MPLABX编程团队表达了他的观点,你就有了暗示。如果这些插件是微芯片,他们可以看进去。如果不是来自公司的人需要与他们联系。
以上来自于百度翻译 以下为原文 Since someone form the MPLAbX programing team expressed his view you have a hint. If any of those plug ins are microchips they could look in to it. If not someone from the company that makes them would need to be put in touch with them. |
嗨,我已经确认Proteus和MPLLABXv3.35&v3.40(webticket)之间有问题。这个问题应该在下一个MPLAB X版本中解决。
以上来自于百度翻译 以下为原文 Hi, I have been confirmed that there is an issue between Proteus and MPLAB X v3.35 & v3.40 (webticket). This issue should be resolved in the next MPLAB X version Regards |
只有小组成员才能发言,加入小组>>
4824 浏览 9 评论
1829 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2954 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
362浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1798浏览 0评论
GMT+8, 2024-4-24 17:09 , Processed in 1.117890 second(s), Total 53, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
