你好
我的名字是pini我在新项目AC / DC转换器上工作 输入为85-265 VAC 输出12vdc / 350mA axiliry:16vdc 芯片:viper013HS 我使用midcom变压器750370024和viper013hs 我不怎么在模拟中设置这个变换器(如何输入参数) 这是EE13 / 7/4但是 我没有全部 变压器的参数 如何正确运行模拟? 谢谢 以上来自于谷歌翻译 以下为原文 Hi my name is pini i work on new project AC/DC converter the input is 85-265 VAC output 12vdc/350mA axiliry :16vdc chip:viper013HS I work with a midcom transformer 750370024 and viper013hs I don't how to set this transformer in simulate (how to enter the parameters) this is EE13/7/4 but I do not have all the parameters of the transformer How can i run the simulation correctly? thanks |
2个回答
你好,
我将您的问题直接转发给了Wurth产品应用工程师,他可以用最好,最完整的方式回答。 他应该在度假,他会尽快回答你。 最好的祝福 以上来自于谷歌翻译 以下为原文 Hello, I forwarded your question directly to the Wurth Product application engineer, who can answer in the best and most complete way. He should be in vacation, he will answer you as soon as possible. Best regards |
你好皮尼,
已私下回答你。但是,我想在这里回答以防其他人正在寻找类似的情况: 要在eDS中进行仿真,您需要以下变压器参数: 来自数据表: 主电感:1.6mH 漏电感:~40uH 匝数比Pri:Sec = 8:1 =>反射电压= 8 * 12.6V =假设输出二极管的压降为0.6V。 以下是我通过的eDS步骤: 如您所见,出于模拟目的,只要给出变压器参数以及峰值电流低于变压器饱和电流的条件,就不需要变压器内部结构: 最好的祝福, 埃米尔 以上来自于谷歌翻译 以下为原文 Hello Pini, Already answer to you on private. However, I would like to also answer here in case that someone else is looking in to similar situation: For your simulation in eDS you need the following parameters for the transformer: From datasheet: Main inductance: 1.6mH Leakage inductance: ~40uH Turns ratio Pri:Sec = 8:1 => reflected voltage = 8*12.6V= assuming a 0.6V drop voltage on the output diode. Here are the steps though eDS that I went through: As you can see, for the simulation purposes, the transformer internal construction is not really needed as long as the transformer parameters are given along with the condition that peak current to be lower that the transformer saturation current: Best regards, Emil |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1209 浏览 1 评论
1832 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1498 浏览 1 评论
2724 浏览 6 评论
4945 浏览 21 评论
292浏览 4评论
335浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
263浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
330浏览 3评论
344浏览 3评论
GMT+8, 2024-3-28 16:13 , Processed in 0.850931 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
