所以我有一个简洁的6 FPGA板,带有4位7段显示器,我需要了解如何使它们工作的基础知识。
我们的教授告诉我们有关阳极和阴极的信息,但我不知道如何使用它们在显示屏上显示数字。 顺便说一句,我正在使用Verilog。 任何帮助深表感谢。 以上来自于谷歌翻译 以下为原文 So I have a spartan 6 FPGA board with a four digit 7-segment display, and I need the basics on how to make them work. Our professor told us about the anodes and cathodes, but I'm not sure how to use them to make numbers on the display. I am using Verilog, by the way. Any help is much appreciated. |
2个回答
>一个四位数的7段显示器,我需要有关如何使它们工作的基础知识
这些基本上是配置良好的LED,以形成数字和粗略字母。 当您想要点亮其中一个LED段时,您可以输出0或1到所需的连接。 您需要阅读电路板用户指南或原理图,以确定哪个Spartan-6 FPGA IO引脚连接到哪个段,然后确定电路板用户指南或组件的数据表,以确定是否需要输出0或 1。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 > a four digit 7-segment display, and I need the basics on how to make them work These are essentially LEDs configured in nice arrangement to form numbers and crude letters. When you want to light up one of the LED segments you either output a 0 or 1 to desired connection. You will need to read the board user guide or schematic to determine which of the Spartan-6 FPGA IO pins is connected to which segment and then the board user guide or the data sheet for the component to determine if you need to output a 0 or 1. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
嗨,
很遗憾你没有提到你正在使用哪个主板。 但是你可以看看digilent NEXYS 3用户指南。 他们有一个部分,他们很好地描述了连接和多路复用控制。 可以在ISE HDL模板(灯泡图标)中找到基本的hex2段解码器。 您需要检查极性是否与您的电路板匹配。 有一个很好的综合 Eilert 以上来自于谷歌翻译 以下为原文 Hi, unfortunately you didn't mention which board you are using. But you can take a look at the digilent NEXYS 3 User guide. They have a section where they describe connection and multiplexing controll very well. A basic hex2segment decoder can be found in the ISE HDL templates (the lightbulb icon). You neeed to check wether the polarity matches with your boards circuit. Have a nice synthesis Eilert |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2590 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2063 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
400浏览 1评论
1504浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2164浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-29 21:27 , Processed in 0.986870 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
