扫一扫,分享给好友
大家好,
我花了几个星期的时间试图找到一种AC / DC转换器小型化的解决方案。 今天我以为我已经找到了使用Viper26和精湛的eDesignSuite工具的解决方案,但是当我分析附加的结果电路时,我只是不明白两个不同接地的含义,用三角形表示(电路接地,我猜)和其他由三条水平条纹代表(也许是地球插头?)。 在丰富的文档ST中,我没有找到任何描述,也没有找到这两种类型的理由的例子,此外,我发现令人震惊的是GND / Source输出直接连接到电路接地并通过D连接到另一个接地(地球插头?)。 我感谢您的帮助。感谢您的时间和关注。 以上来自于谷歌翻译 以下为原文 Hi to all, I take weeks trying to find a solution for miniaturization of an AC / DC Converter. Today I thought I had found the solution with the Viper26 and superb eDesignSuite tool but when I analyzed the attached resulting circuit, I just do not understand the meaning of the two different grounds, represented by a triangle (circuit ground, I guess) and the other represented by three horizontal stripes (earth plug, perhaps?). In the abundant documentation ST, I haven't found anything nor description, nor examples with these two types of grounds, besides, I find it shocking that the GND/Source output is connected directly to the circuit ground and through D to the another ground (earth plug?). I appreciate your help. Thank you for your time and attention. |
2个回答
谢谢Marcello。
我真的不明白这个“设备看到的GND电平”,但实际上,重要的是要有一个正常工作的电路。 我不是说英语的人,所以,我感谢您确认我所说的附加电路是否正确。 新的,谢谢和最好的问候, 以上来自于谷歌翻译 以下为原文 Thank you, Marcello. I really don't understand this ''the GND level seen by the device'', however, in fact, the important thing is to have a functioning circuit. I am not English speaker so, please, I appreciate that you confirm me that the attached circuit with the modifications indicated by you, is correct. Newly, thanks and best regards, |
拜托,马塞洛,你能回答我的上一篇文章吗?谢谢
以上来自于谷歌翻译 以下为原文 Please, Marcello, can you answer my last post?. Thanks |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
503浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
561浏览 3评论
479浏览 3评论
GMT+8, 2024-4-20 04:45 , Processed in 1.288422 second(s), Total 71, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
