大家好!
我正在使用spartan3AN,我正在尝试通过JTAG编程外部PROM xcf01s。 到目前为止,我们一直在使用没有外部存储器的PCB直接编程FPGA,一切正常。 现在,我们将PROM连接到pcb但是内存无法识别,当我尝试初始化链时指示未知设备。 引脚M2,M1,M1与gnd(主 - 串行模式)绑定。您认为这是硬件问题还是我必须通过ise设计套件和影响进行配置? (我已经创建了一个PROM文件)JTAG-PROM-FPGA之间的连接是根据ug332,图3-2,第81页进行的。我还附上了pcb的原理图,以防我遗漏了什么。 (PROM在左下角,U5)。欢迎任何帮助。 SCHEMAtiC1 _ FPGA_USB.pdf 44 KB 以上来自于谷歌翻译 以下为原文 Hello everyone! I'm using spartan3AN and i'm trying to program an external PROM xcf01s through JTAG. Until now, we had been using the pcb without the external memory by programming directly the FPGA and everything worked fine. Now, we attached the PROM to the pcb but the memory is not recognized and when i try to initialize the chain indicates unknown device. Pins M2,M1,M1 are tied to gnd (master-serial mode). Do you think it's a hardware problem or is it something else i have to configure through ise design suite and impact? (I have already created a PROM file) The connection between JTAG-PROM-FPGA is being made according to ug332,figure 3-2,page 81.I've also attached the schematic of the pcb in case i'm missing something. (PROM is at lower left corner,U5). Any help is welcome. SCHEMATIC1 _ FPGA_USB.pdf 44 KB |
4个回答
S3AN设备有一个内部PrOM,为什么你使用外部PROM?
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 The S3AN device has a internal PrOM, why are you using an external PROM?------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
只需按照订单!
这不是我的项目,我没有设计pcb,只是帮助今天编程外部PROM ...我还没有真正研究过,我可以通过JTAG编程内部PROM然后自动配置它的FPGA uppon 充电? 以上来自于谷歌翻译 以下为原文 Just following orders! It's not my project and i didn't design the pcb, only helping today to program the external PROM... I haven't really looked into it, I could just program the internal PROM through JTAG and then the FPGA it's automatically configured uppon power up? |
xcf01s在JTAG链上,TDI,TDO,TCK和TMS是FPGA和EPROM共有的。我已经生成了mcs文件但是影响没有看到xcfs01,它被列为未知设备。无论如何,如果我能
编程内部EPROM一次,然后在加电时加载固件,我可以完成我的工作,不需要使用外部存储器。 谢谢你们。 以上来自于谷歌翻译 以下为原文 The xcf01s is on the JTAG chain,TDI,TDO,TCK and TMS are common to FPGA and EPROM. I've already generated an mcs file but impact doesn't see xcfs01, it is listed as unknown device. Anyway, if I can program internal EPROM once and after that the firmware is loaded upon power up,I could get my job done and there is no need to use the external memory. Thank you all. |
是的,如果模式引脚设置正确,编程内部PROM将在上电时对S3AN器件进行编程。
通过更昂贵的S3AN而不是S3A而不使用内部PROM是极不寻常的。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Yes, programming the internal PROM will program the S3AN device on power up if the mode pins are set correctly. It would be extremely unusual to by the more expensive S3AN instead of the S3A and not use the internal PROM.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-19 13:06 , Processed in 0.951068 second(s), Total 72, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
