你好,
今天我联系您,因为我有一个CY45 31 EZ-PD CGG3评估套件,它符合CYPD3125-40LQXIT 40QFN子卡,并且我想知道USB 2 MIU-B连接器连接到哪个端口,因为在数据表中我找不到它。 此外,我想知道在PSoC Creator的CYPD3125-40LQXIT中,应该在组件目录中使用哪一个组件来代表我的USB 2 Mimi-B和我的USB类型C,那么我应该将哪个端口连接到它们? 谢谢你的回答 热忱地 以上来自于百度翻译 以下为原文 Hello , I contact you today because I have a CY4531 EZ-PD CCG3 Evaluation Kit which comport a CYPD3125-40LQXIT 40QFN Daughter Card, and I would like to know to which port the USB 2.0 Mini-B connector is linked because in the Datasheet I can’t find it. Moreover I would like to know in PSoC Creator in my CYPD3125-40LQXIT, which component should I use in the Component catalog to represent my USB 2.0 mini-B and my USB Type C and so to which port should I link them ? Thank you for your answers Cordially |
3个回答
您可以在CY45 31示意图中检查这与USB迷你B的连接(目前在工具包内容中)。
使用PSoC Creator构建应用程序项目。固件二进制文件将在ELF、十六进制和HEX中生成。 适合于SWD编程、MIIPROG和EZ-PD配置实用工具的CYACD格式。如果你有任何问题,请告诉我们。 以上来自于百度翻译 以下为原文 You can check this in the CY4531 schematics to check the connection to the USB mini B.(present in the Kit contents). Build the application projects using the PSoC Creator. The firmware binaries will be generated in ELF, HEX, and CYACD formats suitable for SWD programming, Miniprog, and the EZ-PD configuration utility. Please try and let us know if you face any issue. |
你好!
有点迟的答案,但很容易重新路由到USB MIIB连接器连接到DC+D -在ccg3 IC上。请看图表,子板,第3页。删除R48和R49,取而代之的是把它们放在R51和R52上,这样你就可以去了(但是现在你必须使用SWD端口加载新的固件,因为你禁用了USB /I2C方式)。 然后,您需要创建自己的USB FS组件,通常基于在EZPD SDK中的DDP GeLE示例中的USB HID/Billboard堆栈。 干杯 奥诺夫 以上来自于百度翻译 以下为原文 Hi! A bit late answer, but it is easy to re-route to USB Mini-B connector to connect to D+/D- on the CCG3 IC. Look in the schematics, daughter board, page 3. Remove R48 and R49 and instead put them on R51 and R52 instead and you are good to go (but now you have to load new firmware using the SWD-port instead since you disabled the USB/I2C way). Then you need to create your own USB FS component, typically based on the USB HID / Billboard stack that you have in the DP Dongle example in the EZPD SDK. Cheers Olof |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
324浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-25 03:29 , Processed in 0.597804 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
