嗨,我有34970A并且有压力传感器连接到它。工作正常,当我添加额外的压力传感器并试图运行数据记录器时,我在计算机上收到一条弹出消息,说“配置与仪器不匹配”。
你知道为什么我收到这条消息以及我应该怎么做才能修复它? 以上来自于谷歌翻译 以下为原文 Hi, I have the 34970A and have pressure transducers connected to it. It worked fine and when I added additional pressure transducers and tried to run the data logger I got a pop up message on the computer saying "configuration does not match instrument". Do you know why I'm receiving this message and what I should do to fix it? |
1个回答
如果更改了交换机模块配置,即添加或删除了交换机模块,则Benchlink Data Logger软件会看到并且不允许配置运行。
遗憾的是,如果必须添加,删除或更改为其他型号的插件模块,则必须打开新配置并完全重建应用程序。 以上来自于谷歌翻译 以下为原文 If the switch module configuration is changed, i.e., a switch module is added or removed, the Benchlink Data Logger software sees that and will not allow the configuration to run. Unfortunately you must open a new configuration and completely rebuild your application if you have to add, remove, or change to a different model plug-in module. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 20:07 , Processed in 1.055185 second(s), Total 70, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
