您好,我正在尝试找到E7495b无线基站测试仪预期灵敏度的规范。
具体而言,有许多软件功能允许无线(OTA)接收商用蜂窝信号,以验证网络性能。 选项可用于GSM,CDMA2K和W-CDMA。 但是,讨论这些软件选项操作的参考手册提到用户应该A)插入感兴趣的基站的测试端口,或者B)将测试盒放在附近的视线内到基站的 利益。 我很欣赏这样一个事实:执行OTA测试并不是一件容易的事情(视线很可能只是一种确保接收器同步和提供有效测量的足够强的SNR的方法),但我想知道是否 如果没有基站的视线,E7495b中存在一些基本的硬件限制,这将限制OTA测量的软件选项成功。 通过内置前置放大器,我假设噪声系数相当低(可能没有商用手机那么低,但可能小于10 dB),即使没有视线也能提供良好的性能。 该手册讨论了无法保证性能的“边际”SNR,但据我所知,测量范围应该比手册中提到的视线要求好一些。 任何有关接收器灵敏度/性能应该在此预期的轶事(或其他)指导将不胜感激。 非常感谢,约翰 以上来自于谷歌翻译 以下为原文 Hello, I'm trying to locate a spec for the expected sensitivity of the E7495b Wireless Basestation Tester. Specifically, there are a number of software features that allow over-the-air (OTA) reception of commercial cellular signals for the purpose of validation of the network's performance. Options are available for GSM, CDMA2K, and W-CDMA. However, the reference manual discussing the operation of these software options mentions that the user should either A) plug in to the test port of the basestation of interest, or B) locate the test box within nearby line-of-sight to the basestation of interest. I appreciate the fact that it isn't an easy task to perform OTA testing (and line-of-sight is likely just a way to ensure sufficiently strong SNR for the receiver to synchronize and provide valid measurements), but I'm wondering if there is some fundamental hardware limitation in the E7495b that would prevent the software options for OTA measurements from being made successfully if line of sight to the basestation isn't available. With the built-in preamp, I'm assuming that the noise figure is reasonably low (maybe not as low as a commercial cell phone, but presumably less than 10 dB), which would provide good performance even without line-of-sight. The manual talks about a "marginal" SNR where performance isn't guaranteed, but from what I can tell, the range of measurement should likely be a good bit better than the line-of-sight requirement called out in the manual. Any anecdotal (or other) guidance of what sort of receiver sensitivity/performance should be expected here would be appreciated. Thanks much, John |
4个回答
嗨John - E7495B的典型显示平均本底噪声(DANL)为435 MHz:-147 dBm / Hz 1005 MHz:-145 dBm / Hz 1960 MHz:-142 dBm / Hz 2140 MHz:-141 dBm / Hz 2500 MHz:
-136 dBm / Hz解调1xEV-DO信号时,使用的带宽为1.25 MHz。 因此,1.25 MHz带宽中的本底噪声将比1 Hz带宽中的本底噪声高出61 dB。 为了使解调测量不受噪声基底的影响,信号电平应比噪声基底高约30 dB。 因此,在1 GHz时,您正在测量的信号(在这种情况下为1xEV-DO信号)应至少为-145 + 61 + 30 = -54 dBm。 问候 - 以上来自于谷歌翻译 以下为原文 Hi John - The typical displayed average noise floor (DANL) for E7495B is 435 MHz: -147 dBm/Hz 1005 MHz: -145 dBm/Hz 1960 MHz: -142 dBm/Hz 2140 MHz: -141 dBm/Hz 2500 MHz: -136 dBm/Hz When demodulating a 1xEV-DO signal, the bandwidth used is 1.25 MHz. So, the noise floor in a 1.25 MHz bandwidth would be 61 dB above the noise floor in a 1 Hz bandwidth. In order for the demodulation measurement to not be affected by the noise floor, the signal level should be about 30 dB above the noise floor. So, at 1 GHz, the signal you are measuring (in this case a 1xEV-DO signal) should be at least -145+61+30 = -54 dBm. Regards - |
你好 !
考虑到E7495B,我注意到灵敏度水平在375MHz的步长上差异接近25dB。 这是预期的水平差异吗? 考虑到FW升级到版本6.25,这次我还有另一个问题。 我的仪器是在5.00,从闪存卡升级时它停止了。 现在我无法再次启动,它运行大约30%的启动过程并停止。 任何人都可以给我一个提示是否仍然可以由用户升级(任何完整的SW软件包上传)或者是否必须将仪器送到安捷伦安装一个全新的软件包? 以上来自于谷歌翻译 以下为原文 Hello ! Considering the E7495B I have noticed that the sensitivity level presents a difference of almost 25dB on that step at 375MHz. Is that the expected level difference ? I also have another question this time considering the FW upgrade to release 6.25. My instrument was at 5.00 and while upgrading from a flash card it stopped. Now I cannot boot again, it runs about 30% of the booting process and stops. Can anyone please give me a hint whether it still can be upgraded by the user (any complete SW package to be uploaded) or whether the instrument has to be sent to Agilent to install a complete new SW package ? |
嗨 - 看起来我们的正常现场固件安装过程无法解决的固件或CPU出现问题。
我们的服务中心还有一个额外的升级过程,可以更改CPU上的DIP开关设置,使仪器完全从存储卡启动。 因此,我建议将仪器送至安捷伦服务中心进行维修或技术处理。 问候 - 以上来自于谷歌翻译 以下为原文 Hi - It appears that there is something wrong with the firmware or CPU for which our normal field firmware installation process cannot fix. Our service centers have an additional upgrade process whereby the dip switch setting on the CPU can changed to allow the instrument to boot completely from a memory card. Therefore, I recommend sending the instrument in for repair or tech eval to an Agilent service center. Regards - |
醉狼工作室 发表于 2019-6-28 07:47 亲爱的Tallbott! 我非常感谢您提供宝贵的信息。 我将把它带到服务中心,我将联系GemanyBöblingen的安捷伦服务中心,非常感谢您的快速回复! 最好的祝福 ! 以上来自于谷歌翻译 以下为原文 Dear Tallbott ! I thank you very much for your valuable information. I certaily will take that to a service center, I will contact the Agilent Service Center in Böblingen, Gemany, Thanks a lot for you very fast replies ! Best regards ! |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1845 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1546 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
349浏览 0评论
1385浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
261浏览 0评论
2248浏览 0评论
1102浏览 0评论
GMT+8, 2024-3-28 20:50 , Processed in 1.004347 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
