我一直在各种项目中使用Spartan 3 xc3s4000-4fg900!
现在我们知道它现在已经过时,那么它的引脚兼容和外设兼容设备是什么? 以上来自于谷歌翻译 以下为原文 I have been using Spartan 3 xc3s4000-4fg900 in various projects! Now as we know that its obsolete now so what will be its pin compatible and peripheral compatible device? |
2个回答
你还能订购这部分,还是-5(更快)速度等级的相同部分?
我相信两者的答案都是'是'。 器件系列之间没有引脚兼容性(Spartan-3 vs. Spartan-3a vs. Spartan-3e vs. Spartan-6)。 如果您有兴趣选择可以购买多年的零件,那么请考虑一个最近的器件系列中的非引脚兼容器件。 如果您有兴趣维护当前的FPGA设计和电路板,那么请购买您当前使用的FPGA,或者购买相同器件的更快速度等级。 您也可以咨询Xilinx销售代表以获取指导。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Can you still order this part, or the same part in the -5 (faster) speed grade? I believe the answer to both is 'YES'. There is no pin-compatibility across device families (Spartan-3 vs. Spartan-3a vs. Spartan-3e vs. Spartan-6). If you are interested in selecting a part which can be purchased for many years to follow, then consider non-pin-compatible devices in one of the more recent device families. If you are interested in maintaining the current FPGA design and circuit boards, then purchase the FPGA you are currently using, or a faster speed grade of the same device. You can also consult your Xilinx sales rep for guidance. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing.View solution in original post |
我相信两者的答案都是'是'。 器件系列之间没有引脚兼容性(Spartan-3 vs. Spartan-3a vs. Spartan-3e vs. Spartan-6)。 如果您有兴趣选择可以购买多年的零件,那么请考虑一个最近的器件系列中的非引脚兼容器件。 如果您有兴趣维护当前的FPGA设计和电路板,那么请购买您当前使用的FPGA,或者购买相同器件的更快速度等级。 您也可以咨询Xilinx销售代表以获取指导。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Can you still order this part, or the same part in the -5 (faster) speed grade? I believe the answer to both is 'YES'. There is no pin-compatibility across device families (Spartan-3 vs. Spartan-3a vs. Spartan-3e vs. Spartan-6). If you are interested in selecting a part which can be purchased for many years to follow, then consider non-pin-compatible devices in one of the more recent device families. If you are interested in maintaining the current FPGA design and circuit boards, then purchase the FPGA you are currently using, or a faster speed grade of the same device. You can also consult your Xilinx sales rep for guidance. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2590 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2063 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
400浏览 1评论
1504浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2164浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-29 20:38 , Processed in 1.063412 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
