嗨,我希望有人可以帮助我,我已经尝试在VEE中使用Excel(创建一个新的工作簿,创建...)我替换(创建线图...)通过(创建XYchart)并配置它。
当我点击运行时出现错误信息(编号2004)出现告诉我:这些工作簿无法在当前工作簿中找到:Sheet1注意:我使用非法国办公室版本如何纠正这些错误我不明白这些注意事项和 我认为这是我的问题的解决方案:如果您使用的是非英语Office,请参阅此对象的上下文菜单 - > Excel帮助 - > Notes以了解如何使用左下角的三个对象来本地化“Sheet1” 串。 怎么能帮到我 以上来自于谷歌翻译 以下为原文 Hi i hope that some one can help me i have tryed to use Excel in VEE (create a new workbook, create ...) i replace (create Linechart...) by (create XYchart) and i configure it. when i click in run an error message (number 2004) appear tell me that: these sheet cannot be found in the current Workbook: Sheet1 note : i use a non French office version how can correct these error i haven't understand these note and i think that is the solution of my problem : If you are using non-English Office, see this object's context menu -> Excel Help -> Notes to learn how to use the three objects in the lower left corner to localize the "Sheet1" string. how can help me 附件
1个回答
谢谢*上帝* ...问题解决了这些解决方案断开“XY图表设置”对象和“调用xlLib.CreateXYChart”对象之间的界限并连接左下角“Localize ...”输出的一行
“对象输入”调用xlLib.CreateXYChart“对象。 这会将ChartSheet和DataSheet字段的ChartSettingsRecord值修改为适用于任何版本的Microsoft Office Excel的第一个现有工作表的值。 以上来自于谷歌翻译 以下为原文 thanks *God* ... probleme solved these is the solution Disconnect the lines between the "XY Chart Settings" object and the "Call xlLib.CreateXYChart" object and connect a line from the output of the bottom-left "Localize..." object to the input of the "Call xlLib.CreateXYChart" object. This will modify the ChartSettingsRecord values for the fields ChartSheet and DataSheet to a value that is correct for the first existing worksheet for any version of Microsoft Office Excel. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 22:36 , Processed in 1.126260 second(s), Total 69, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
