嘿,我正在试着建立一个USB引导加载程序,这样我可以通过以太网更新我的网站。我的六角形文件上传到u***闪存驱动器和我的网站工作正常。所以我只需要引导引导程序工作。这里开始出现麻烦。我试图从微芯片基本u***引导加载程序项目开始,并遵循了.ony_help文件中的说明。我的PIC32MZ EF启动器套件在我对引导加载程序进行编程之后闪烁着红色(正如它应该的那样),但是当我插入闪存驱动器时,闪烁的LED就变成了常量变暗的状态。这个问题已知吗?有人知道如何解决这个问题吗?(我在使用HARMony 1.08.01)我从未尝试过设置引导加载程序,所以这个任务对我来说相当新,我不知道如何从这里开始。非常感谢您的帮助:)
以上来自于百度翻译 以下为原文 Hey, I currently trying to build a USB-bootloader, so I can update my project with my website via Ethernet. My hex-file upload to a u*** flash drive with my website works fine. So I just need to get the bootloader working. Here starts the trouble. I tried to start with microchips basic u*** bootloader project and followed the instructions in the harmony_help file. My PIC32MZ EF starter kit is blinking red after I programmed the bootloader (as its supposed to), but when I insert the flash drive the blinking LED just turns into a constand dimmed state. Is this issue known and does someone know how to fix this? (Im using Harmony 1.08.01) I never tried to set up a bootloader so this task is rather new for me and I have no idea how to start here. Any help is mutch appreciated :) |
1个回答
你好,M4x基本的USB引导加载程序通常要求你在一台通过USB线缆连接到目标的电脑上运行微芯片引导加载程序。根据你的描述,听起来好像你正在直接将USB存储器/闪存设备插入目标——这是正确的吗?你的目标是什么?微芯片板还是定制板?我有两个引导加载程序通过u***和PIC32通过以太网和USB在PIC18上运行,但没有一个直接从USB存储器设备读取数据。
以上来自于百度翻译 以下为原文 Hi M4x The basic USB bootloader usually requires you to run the Microchip bootloader application on a pc that is connected to your target via a USB cable. From your description it sounds as if you are plugging your USB memory/flash device directly into the target - is this correct ? What is your target ? a Microchip board or a custom board ? I have a couple of bootloaders running on both PIC18 via u*** and PIC32 via ethernet and USB, but none of them reads data directly from an USB memory device. Regards Søren |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1748 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2955 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1800浏览 0评论
GMT+8, 2024-4-25 21:31 , Processed in 1.227061 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
