你好!我已经解决了这个问题:当我按下Studim & Gt;FX3--GT;SPI闪存控制中心说:等待CyPress引导程序员设备枚举时,它说:CyPress引导程序员设备没有找到,并且在Windows设备管理器FX3中显示为未被识别的设备。我的设置是:J96 2和lt;-& 3;J97打开J98 2和lt;->3 SW25 1关闭SW25 2关闭SW25 3,而我的板是:PCB:600 -600–15 01 RV03如何解决这个问题?谢谢
以上来自于百度翻译 以下为原文 Hi! I've go this problem: as soon as I press PROGRAMM->FX3->SPI FLASH control center says: waiting for cypress boot programmer device to enumerate then it says: cypress boot programmer device not found and in windows device manager fx3 appears as not recognized device. My settings are: J96 2<->3 J97 open J98 2<->3 SW25 1 OFF SW25 2 OFF SW25 3 ON and my board is: PCB: 600-60015-01 rev03 how can i solve this issue? THANKS |
2个回答
你好,
PMOD设置很好。 实际上,当你点击FX3——& GT;SPI Flash时,它会将BooDealver代码下载到FX3中,并用VID -04B4和PID - 4720枚举。看起来它不是自动绑定到驱动程序的。因此,请尝试手动绑定此驱动程序(CysB3.IF位于C:程序文件(x86) CyPress EZ-USB FX3SDK 1.2 驱动 bin Win 7x64)。 您可以通过右键单击设备(设备管理器)并按下“更新驱动程序”来实现这一点。导航到CysB3.IF的位置。 在这样做之后,您可以点击重置并尝试编程SPI闪存(FX3-和GT;SPI闪存)。然后它应该直接向你询问.img文件。 请确保J101到104连接在2和3之间,以便成功地编程SPI闪存。 谢谢, Sai Krishna。 以上来自于百度翻译 以下为原文 Hi, PMOD settings are fine. Actually when you click on FX3-->SPI FLASH then it will download the bootprogrammer code into FX3 and it will enumerate back with VID - 04B4 and PID - 4720. It looks like it is not binding to the driver automatically. So please try binding this driver manually (CyUSB3.inf located in the C:Program Files (x86)CypressEZ-USB FX3 SDK1.2driverbinwin7x64). You can do this by right clicking on the device (in Device Manager) and press "Update Driver". Navigate to the location of CyUSB3.inf. After doing this, you can hit reset and try to program the SPI FLASH (FX3-->SPI FLASH). Then it should be directly asking you for the .img file. Please make sure that J101 to 104 are connected between 2 and 3 to successfully program the SPI FLASH. Thanks, Sai Krishna. |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-20 11:33 , Processed in 0.627633 second(s), Total 67, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
