您可以将从示波器获得的波形的X轴和Y轴的值下载或导入到函数发生器中以用作输出吗?
以上来自于谷歌翻译 以下为原文 Can you download or import the values of the X and Y axis of a waveform obtained from the oscilloscope into a function generator to be used as the output? |
1个回答
是的,Intuilink波形编辑器会将从示波器获得的波形的X轴和Y轴的值下载到函数发生器中以用作输出。
步骤如下:1。 使用Microsoft Excel或文本编辑器打开包含X和Y轴值的文件。 删除显示的X和Y轴的标题。 将X轴和Y轴的值保存为CSV(逗号分隔)(* .csv),文本(* .txt)或PRN(空格分隔)(* .prn)格式。 启动Intuilink波形编辑器软件。 选择文件 - >打开并加载保存到波形编辑器中的文件。 然后它将显示正在保存的值的波形。 选择Communications - > Connection并选择用于连接函数发生器的连接。 选择通信 - >发送波形。 设置要输出的波形的频率,幅度和偏移。 如果要在函数发生器上保存波形,请选择Memory Name并键入波形名称,否则选择Volatile Memory.9。 通过单击波形和参数或仅波形参数,选择是仅发送波形参数还是仅发送波形和参数。 完成所有操作后,单击发送按钮将波形发送到函数发生器以进行输出。请注意,33120A最少支持8个点,最多可支持16K点。 33220A和33250A最多可支持64K点.Intuilink波形编辑器工具可在此处下载:http://www.home.agilent.com/agilent/editorial.jspx?cc = US& lc = eng& ; CKEY = 1000000918:EPSG:SUD&安培; NID = -536902257.536883183和ID = 1000000918:EPSG:SUD 以上来自于谷歌翻译 以下为原文 Yes, the Intuilink Waveform Editor will download the values of the X and Y axis of a waveform obtained from the oscilloscope into a function generator to be use as the output. The steps are as follows: 1. Open the file that contains the values of the X and Y axis using Microsoft Excel or Text editor. 2. Remove the header of the X and Y axis shown. 3. Save the values of the X and Y axis into a CSV (Comma Delimited) (*.csv), Text (*.txt) or PRN (Space Delimited)(*.prn) format. 4. Start the Intuilink Waveform Editor Software. 5. Select File -> Open and load the file saved into the waveform editor. It will then display the waveform of the values that was being saved. 6. Select Communications -> Connection and select the connection you are using to connect up to the Function Generator. 7. Select Communications -> Send Waveform. Set the Frequency, Amplitude and Offset for the waveform that you would like to output. 8. If you would like to save the waveform on the Function Generator, Select Memory Name and key in a name for the waveform otherwise select Volatile Memory. 9. Select whether you would like to send only the waveform parameters only or the waveform and the parameters by clicking on the Waveform and Parameter or the Waveform Parameters only. 10. When all is completed, click on the Send button to send the waveform over to the Function Generator to be output. Please take note that the 33120A can support a minimum of 8 points and up to a maximum of 16K points. The 33220A and the 33250A can support up to a maximum of 64K points. The Intuilink waveform editor tool can be downloaded here: http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=1000000918:epsg:sud&nid=-536902257.536883183&id=1000000918:epsg:sud |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 12:02 , Processed in 1.208556 second(s), Total 68, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
