你好,
我正面临着关于STM32l073低功耗的问题。在我的核板NUCLEO-L073上,当我进入停止模式时,我的消耗量大约是1和3uA,所以一切似乎都没问题。然后,我们决定制作我们自己的板(参见附件),使用相同的代码,我消耗大约30uA,我真的不知道为什么???唯一的区别是封装,根据我们自己的设计,我们使用的是stm32l073 LQFP48(48pin),而在核心上,这是64个引脚。由于我不是电子专家,我不知道如何调查这个问题。 如果您对可能出现的问题有所了解,或者我做错了什么,请不要犹豫,分享。 先谢谢你, 最好的祝福, Aurlien #lqfp48 #stm32l073 #current-consumption #electronic-design #electronic #help #mcu #stop-mode #low-power 以上来自于谷歌翻译 以下为原文 Hello, I'm facing an issue regarding low power on stm32l073. On my nucleo board NUCLEO-L073, when i go in stop mode, my consumption is around 1 and 3uA, so all seem to be ok. Then, we decided to make our own board (cf. attached file), with the same code, i consume around 30uA and i really don't know why ??? The only difference is the package, on our own design, we are using a stm32l073 LQFP48 (48pin) whereas on the nucleo this is a 64 pins. As i'm not an expert in electronic, i don't know how to investigate this issue. If you have idea about the possible issue, or if i'm doing something wrong don't hesitate to share. Thank you in advance, Best regards, Aur�lien #lqfp48 #stm32l073 #current-consumption #electronic-design #electronic #help #mcu #stop-mode #low-power |
6个回答
人们只能尝试做一些有根据的猜测!
与Nucleo最明显的区别是PH0缺少MCO输入:你是否正确地调整了你的软件? 简而言之,确保未启用HSE并正确管理PH0 / PH1以实现低功耗。 - 洛朗 以上来自于谷歌翻译 以下为原文 One can only try to make some educated guesses ! The most visible difference with Nucleo is the lack of MCO input on PH0: did you correctly adapt your software for that ? In short, make sure HSE is not enabled and PH0/PH1 are correctly managed for low power. -- Laurent |
你好,
非常感谢你的答复。我已经验证了,所有关于MCO和HSE似乎都没问题。实际上,我有两个插在一起的板,我宁愿认为它可能来自这两块板之间的连接。我想我在这两块板之间没有足够的VSS和VDD引脚连接。 问候, 光环©留置权 以上来自于谷歌翻译 以下为原文 Hello, Thank you very much for the reply. I have verified and all seems to be ok regarding MCO and HSE. Actually, i have two boards that are plugged together, i d rather think it could come from the connectivity between those two boards. I think i don't have enough VSS and VDD pin connected between those two boards. Regards, Aurélien |
你好,
实际上,自从我在自己的主板上焊接了我的stm32l073后,我仍然面临一个问题。我已经在PCBWay上打印了电路板,我使用smd工作站焊接了STM。但是我的消耗仍然高于我的预期,也就是说20uA,我不知道为什么因为它应该低于3uA(事实上,当我在核板上加载相同的软件时,一切都可以目前的消费)。目前,我只焊接了STM +去耦电容。 如果您有任何想法,请随时分享 问候, 光环©留置权 以上来自于谷歌翻译 以下为原文 Hello, Actually, i'm still facing an issue since i have soldered my stm32l073 on my own board. I have made printed the boards on PCBWay and i have soldered the STM by using a smd workstation. But my consumption is still above what i'm expecting, that is to say arround 20uA and i don't know why because it should be under 3uA (indeed, when i load the same software on the nucleo board, all is ok regarding the current consumption). For now, i have soldered only the STM + the decoupling capacitors. If you have any ideas, pls feel free to share Regards, Aurélien |
如果在BOOT0上使用100K下拉电阻,电流是否会下降
以上来自于谷歌翻译 以下为原文 Does current drop if you use a 100K pull-down on BOOT0 |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
503浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
552浏览 3评论
479浏览 3评论
GMT+8, 2024-4-19 17:47 , Processed in 0.743798 second(s), Total 75, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
