要用STM32F4芯片内部ADC采集一路频率为50hz的正弦信号,要求的采样点是一个周期20点,即采样频率为1Khz。我使用的采样方式是ADC+DMA+tiM,用定时器生成一个PWM然后触发ADC采样,DMA配置的是每传输20次生成一个完成中断。 现在按照这种方式可以实现采样,但是采样出来的数据不是按照我设置的频率进行,我设置的 频率是1khz但是采样出来的数据并没有1ms采集一次,我把数据用串口打印出来然后用EXCEL绘图发现一个周波里面不止20个点,不知道为什么会产生这问题。后面我在DMA完成中断中加一条代码让一个引脚不断翻转然后我用示波器测量他的频率发现频率为53hz,这个频率说明我是20ms完成一次传输哇,真是搞不懂为什么合成的波形就是不对。 相关代码: //ADC配置 void Adc_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; ADC_InitTypeDef ADC_InitStructure; ADC_CommonInitTypeDef ADC_CommonInitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE); /* PF4->IN14, PF5->IN15 */ GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_NOPULL; GPIO_InitStructure.GPIO_OType=GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_Init(GPIOF, &GPIO_InitStructure); ADC_CommonInitStructure.ADC_Mode=ADC_Mode_Independent; ADC_CommonInitStructure.ADC_Prescaler=ADC_Prescaler_Div6; ADC_CommonInitStructure.ADC_DMAAccessMode=ADC_DMAAccessMode_Disabled; ADC_CommonInitStructure.ADC_TwoSamplingDelay=ADC_TwoSamplingDelay_5Cycles; ADC_CommonInit(&ADC_CommonInitStructure); ADC_InitStructure.ADC_Resolution=ADC_Resolution_12b; ADC_InitStructure.ADC_ScanConvMode=DISABLE; ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right; ADC_InitStructure.ADC_ContinuousConvMode=DISABLE; ADC_InitStructure.ADC_NbrOfConversion=1; ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_T8_CC1; ADC_InitStructure.ADC_ExternalTrigConvEdge=ADC_ExternalTrigConvEdge_Rising; ADC_Init(ADC3, &ADC_InitStructure); /* 规则通道选择 */ ADC_RegularChannelConfig(ADC3, ADC_Channel_14, 1, ADC_SampleTime_480Cycles); #if USE_ADC_DMA ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE); ADC_DMA_Config((uint32_t*)Test_Var.Databuf[0], (uint32_t*)Test_Var.Databuf[1], 20); ADC_DMACmd(ADC3, ENABLE); #else ADC_EOCOnEachRegularChannelCmd(ADC3, ENABLE); ADC_ITConfig(ADC3, ADC_IT_EOC, ENABLE); #endif ADC_NVIC_Config(); ADC_Cmd(ADC3, DISABLE); Adc_SampleFre_Config(); } //采样频率配置 void Adc_SampleFre_Config(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure; TIM_OCInitTypeDef TIM_OCInitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE); TIM_TimeBaseInitStructure.TIM_Period=999; TIM_TimeBaseInitStructure.TIM_Prescaler=41; /* 1000k */ TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up; TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1; TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0; TIM_TimeBaseInit(TIM8, &TIM_TimeBaseInitStructure); //TIM_SelectOutputTrigger(TIM8, TIM_TRGOSource_Update); TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_Pulse=500; TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low; TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable; TIM_OC1Init(TIM8, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM8, ENABLE); TIM_CtrlPWMOutputs(TIM8, ENABLE); /* for TIM1/TIM8 */ // TIM_ARRPreloadConfig(TIM8, ENABLE); TIM_Cmd(TIM8, DISABLE); } //开始采样 void ADC_Start(void) { #if USE_ADC_DMA // ADC_DMA_Config(); DMA2->LIFCR = ((uint32_t)0x0000007D); while(DMA_GetCmdStatus(DMA2_Stream0)!= DISABLE); DMA2_Stream0->CR |= (uint32_t)DMA_SxCR_EN; /* 使能DMA2_Stream0 */ #endif ADC3->CR2 |= (uint32_t)ADC_CR2_ADON; /* 使能ADC3 */ TIM8->CR1 |= TIM_CR1_CEN; /* 使能定时器8 */ }
2个回答
定时器分频系数哪里我写错了,应该是83。这个是我后面换定时器导致的
问题找到了,问题就是这个定时器频率我没搞清楚导致采样率是设置值的两倍。定时器的频率要根据总线分频系数确定
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
579 浏览 1 评论
794 浏览 0 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
614 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1413 浏览 2 评论
1634 浏览 2 评论
GMT+8, 2024-4-19 15:07 , Processed in 0.617418 second(s), Total 69, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
