有什么方法可以让图标在使用4K显示器时变大?我发现了“小工具栏图标”选项,但是“巨大工具栏图标”选项在哪里呢?还有,关闭标签的“X”太小了。大多数窗口的字体都很容易更改,但是您必须查看几个不同的地方。几个窗口默认为非常小的大小,并且必须调整大小以查看其中的内容。
以上来自于百度翻译 以下为原文 Is there any way to make the icons larger when using a 4K display? I found the 'Small Toolbar Icons` option, but where is the 'Huge Toolbar Icons' option?! Also, the 'X' to close a tab is impossibly small. Fonts for most windows are fairly easy to change, but you have to look in several different places. Several windows default to a very small size, and have to be resized to see whats in them. |
4个回答
什么操作系统?以下是与4k监视器有关的其他帖子。http://www..hip.com/for./FindPost/859957http://www..hip.com/for./FindPost/921153
以上来自于百度翻译 以下为原文 What OS ? Here are other posts relating to 4k monitors. http://www.microchip.com/forums/FindPost/859957 http://www.microchip.com/forums/FindPost/921153 |
Windows 10。其他帖子显示这个问题已经超过一年半了!虽然,他们谈论字体缩放,这似乎大多是好的。主要是那些小图标使得它变得不可用。Netbeans中有很多针对这个问题的google结果,但是它们似乎都没有为MPLABX做任何事情。最常见的建议似乎是:Open C:Program FilesNetBeans 8.0etcnetbeans.confChange-J-Dsun.java2d.dpi.=trueto-J-Dsun.ja。Va2D.DPIAcess = FalSEi尝试使用MPLABIDEIDE.CONF文件,但它似乎没有任何效果。
以上来自于百度翻译 以下为原文 Windows 10. Those other post show that this problem is over a year and a half old! Although, they do talk about font scaling, which mostly seems to be ok. It's mainly the tiny icons that make it unusable. There are plenty of google results for this problem in Netbeans, but none of them seem to do anything for MPLABX. The most common suggestion seems to be:
我查阅了“D:微芯片和谐v1_09实用程序mpfs_.src”并将其加载到Netbeans中。我花了相当长的时间来更改所有默认值,因此在我的4k监视器上可以看到所有内容。4k意识。很多值是硬编码的。我硬编码所有的东西都更大,并且它工作。有可能使它动态,但是会花费我相当多的时间,因为我不是netbean的狂热爱好者。如果X程序员被要求使所有4k意识并且考虑到预算,这是不可能的让X4K有用。我只能希望未来版本的netbean能够支持4k并且X能够被迁移。我开始看到大于4k的屏幕,我真的希望当netbean改变时,能够考虑到更大的屏幕。快一点。
以上来自于百度翻译 以下为原文 I looked in "D:microchipharmonyv1_09utilitiesmpfs_generatorsrc" and loaded it into Netbeans It took me considerable time to change all the defaults so everything was visible on my 4k monitor. I conclude from this exercise the problem is in the defaults used in netbeans and the libraries are not 4k aware. Many of the values are hard coded. I hard coded everything to be larger and it works. It is possible to make it dynamic but would take me quite a bit more time as I am not a netbeans aficionado. If the X programmers were asked to make everything 4k aware and given the budget it is possible to make X 4k useful. I can only hope some future version of netbeans becomes 4k aware and X is migrated. I am starting to see screens larger than 4k, I do hope when netbeans changes it takes into account the possibility of larger screens. If the Microchip testers had Windows 10 machines and 4k screens maybe it would happen sooner. |
嗨,我有完全相同的问题!我认为这是一个巨大的问题。现在越来越多的笔记本电脑和显示器的屏幕是1080p或4K左右,而MPLAB-X在这些机器上完全不能使用。Microchip,你能告诉我们是否已经有人在处理这个问题了?问候,迈克
以上来自于百度翻译 以下为原文 Hi, i'have the exact same problem! And i think it's a huge problem. There's a rising number of notebooks and monitors with >1080p or 4K screens and MPLAB-X is totally unusable on these machines. Microchip, can you tell us if theres already someone working on this problem? Regards, Mike |
只有小组成员才能发言,加入小组>>
4764 浏览 9 评论
1807 浏览 8 评论
1719 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2932 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2039 浏览 5 评论
413浏览 1评论
1095浏览 1评论
求助帖:MPLABX v6.00 + XC32 V4.00 貌似编译文件过多会无法编译
2341浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
337浏览 0评论
246浏览 0评论
GMT+8, 2024-3-19 10:20 , Processed in 0.874508 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
