发 帖
原厂入驻New
[问答] 请问我需要用跳线设置做什么吗?
228 xilinx 处理器
分享
嗨,
我正在使用xilinx网站的网络服务器参考设计,我能够成功生成比特流,并且我能够构建allapplications。但是当我将比特流下载到我的SPARTAN3A入门套件中时,我收到以下错误。
“错误:MDT  - 处理器microblaze_0的各种程序头之间检测到内存重叠......”
我需要用跳线设置做什么吗?
有人帮我解决问题。
PS:Spartan 3A支持xilinx网站上提供的网络服务器参考设计文件(来源:http://www.xilinx.com/products/boards/s3astarter/files/s3ask_webserver.pdf)
谢谢
SD
以上来自于谷歌翻译
以下为原文
Hi,
I am using the webserver reference design from xilinx website, i could able to generate bit stream successfully, and i could be able to build all applications. but when i download bit stream into my SPARTAN 3A starter kit, i am getting the following error.
"ERROR:MDT - Memory overlap detected between various program headers for processor microblaze_0 ... "
do i need to do anything with jumper settings?
anyone help me with solution.
PS: Spartan 3A supports the webserver reference design files given in the xilinx website( source: http://www.xilinx.com/products/boards/s3astarter/files/s3ask_webserver.pdf)
Thanks
SD
2019-6-17 09:11:23   评论 分享淘帖 邀请回答
相关问题
4个回答
你好,
检查链接器脚本并确保两个应用程序都未初始化为BRAM。
问候
--------------------------------------------请注意 - 请注明
如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K--
以上来自于谷歌翻译
以下为原文
Hello,
Check your linker script and make sure that both applications are not initialized to BRAM's.
Regards
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
2019-6-17 09:17:36 评论
举报
当我运行BERT参考设计时,我也遇到了问题。我的消息如下:
错误:MDT  - 在处理器ppc405_0的各种程序头之间检测到内存重叠
我不知道楼上的意思是什么?有没有人给出精心设计的方法?
谢谢!!
以上来自于谷歌翻译
以下为原文
I was also hobbled by the problem when I run the BERT reference design.My message as following:
ERROR:MDT - Memory overlap detected between various program headers for processor ppc405_0
and I don't know what the upstair mean?did anyone give the elaborate method?
Thanks!!
2019-6-17 09:25:38 评论
举报
如果将多个软件应用程序项目初始化为BRAM,则通常会显示此类错误。
何塞
以上来自于谷歌翻译
以下为原文
If more than one software application project is initialized to BRAMs, such an error shows usually.
Jose
2019-6-17 09:39:36 评论
举报
它实际上是因为初始化为xps-bram-cntrl的内存小于你的代码所需的内存所以只需增加内存并生成链接器脚本...欢呼
以上来自于谷歌翻译
以下为原文
it is actually cause the memory initialized to xps-bram-cntrl is less than what your code takes so just increase the memory and linker script would be generated ...cheers
2019-6-17 09:58:59 评论
举报
只有小组成员才能发言,加入小组>>
98个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
