大家好,
所以我有一个闪亮的新SP605和XM105配合它。 我正在设计视频/音频采集卡,并且在制作FMC变体之前将在XM105上进行调试。 我想知道S6引脚的电压稳健性。 我知道它们在FMC卡上的运行速度为2.5v,这是否意味着我需要在扩展卡上的3.3v逻辑和FPGA连接之间安装QuickSwitches(或类似设备)? 通常我会这么认为,但我昨晚读到“某个地方”(对不起,新宝宝,这意味着在喂食/摇摆时有很多额外的时间阅读网络 - 新生儿睡觉(iPad很棒!),但是 很少实际的睡眠......)如果3.3v信号作为扩展线上的输入呈现,S6就可以了......驱动2.5v就可以了(2v以上的任何东西都算作逻辑高)但是我 在我真正得到它的任何用途之前,我不想炸毁这张漂亮的新卡! 谢谢 西蒙 以上来自于谷歌翻译 以下为原文 Hi all, So I have a shiny new SP605 and the XM105 to go with it. I'm in the process of designing a video/audio-capture card, and will be debugging it on the XM105 before making an FMC variant. I was wondering about the voltage robustness of the S6's pins. I know they're running at 2.5v on the FMC card, so does that mean I need to put QuickSwitches (or similar) in place in-between my 3.3v logic on the expansion card and the connection to the FPGA ? Normally I'd assume so, but I read "somewhere" last night (sorry, new baby, which means lots of extra time for reading the web while feeding/rocking-the newborn-to-sleep (iPad's are great!), but very little actual sleep...) that the S6 would be ok if a 3.3v signal was presented as an input on the expansion lines... Driving 2.5v will be fine (anything above 2v will count as logic-high) but I don't want to blow up the nice new card before I really get any use out of it! Thanks Simon |
3个回答
我很担心我对这个问题缺少一些细微差别,所以我会做一个通用的陈述。
无论bank电压如何,Spartan-6输入都可以安全地接收3.3v信号。 查看数据表中的Vin规格: http://www.xilinx.com/support/documentation/data_sheets/ds162.pdf 据我所知,XM105只是为FPGA创建了一个简称。 问候, 乔恩 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I'm worried I'm missing some nuances with this question, so I'll make a generic statement. Spartan-6 inputs, regardless of bank voltage can safely receive 3.3v signals. Check out the Vin spec in the data sheet: http://www.xilinx.com/support/documentation/data_sheets/ds162.pdf As far as I'm aware the XM105 is just creating a short to the FPGA. Regards, Jon View solution in original post |
无论bank电压如何,Spartan-6输入都可以安全地接收3.3v信号。 查看数据表中的Vin规格: http://www.xilinx.com/support/documentation/data_sheets/ds162.pdf 据我所知,XM105只是为FPGA创建了一个简称。 问候, 乔恩 以上来自于谷歌翻译 以下为原文 I'm worried I'm missing some nuances with this question, so I'll make a generic statement. Spartan-6 inputs, regardless of bank voltage can safely receive 3.3v signals. Check out the Vin spec in the data sheet: http://www.xilinx.com/support/documentation/data_sheets/ds162.pdf As far as I'm aware the XM105 is just creating a short to the FPGA. Regards, Jon |
不 - 没有细微差别。
我很少被指责微妙[笑] 谢谢你 - 事实上我确实在我面前打开了ds162中的table-2,但不知怎的,我错过了描述中的“所有i / o标准”部分...我将摆脱Quickswitches然后:) 干杯! 西蒙。 以上来自于谷歌翻译 以下为原文 Nope - no nuances. I'm rarely accused of being subtle [grin] Thanks for that - I did in fact have table-2 in ds162 open in front of me, but somehow I missed the "All i/o standards" part of the description... I'll get rid of the Quickswitches then :) Cheers! Simon. |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-20 11:23 , Processed in 0.982990 second(s), Total 69, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
