扫一扫,分享给好友
你好,我正在使用USB2412B通过模拟开关(74HC4051)来连接计算机的USB端口,以选择和USB端口(下游),并将其连接到USB Mamory棒(上游)。这在一些计算机(PC和笔记本电脑)上工作,但是新电脑不工作,PC不识别USB集线器。我想我必须在4051的输出和USB2412的下游输入之间放置一些东西,但是我已经测试了所有的可能性,但没有结果。有人知道如何改进吗?也许配置不好?我考虑了USB电流保护,但我不认为这是问题。提前感谢您的时间。
以上来自于百度翻译 以下为原文 Hi, i'm using the USB2412B to interface USB ports from computers via an analog switch ( 74HC4051 ) to select and USB port ( Downstream ) and connect it to a USB Mamory stick ( Upstream ). This is working with some computers( PC and laptops ) but with new ones is not working and the PC does not recognize the USB Hub. I think i have to put something between 4051 output and USB2412 downstream input but i have tested with all possiblilities without results. Does anybody knows how to improve it? Maybe it is not well configured? I ommited USB current protection but i don't think this would be the problem. Thanks in advance for your time. |
2个回答
你需要限制D+和D-到3PFD的吸引力。现代4051的带宽大约为20MHz。你会通过全速(12Mhz)信号很好,但在高速(480Mhz)将无法通信。解决方案是使用开关额定通过480Mhz信号。看看UBS340 USB交换机。
以上来自于百度翻译 以下为原文 You need to limit captivate loading on D+ and D- to less than 3pfd. A modern 4051 has a bandwidth around 20Mhz. You'll pass the Full Speed (12Mhz) signal fine, but at High Speed (480Mhz) will fail to communicate. Solution is to use a switch rated to pass the 480Mhz signal. Take a look at the USB3740USB Switch. |
非常感谢你的回答。这听起来真的是我所怀疑的。我会尝试使用UBS340。另一次,谢谢你的专家观点。
以上来自于百度翻译 以下为原文 Many thanks for the answer. It sounds really what i suspected about. I will try with the USB3740. Another time, thanks for your expert view. |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-18 04:12 , Processed in 1.230112 second(s), Total 74, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
