您好,如果我想使用SPC5 Connect通过CAN对MCU进行编程,我需要在SPC5 Connect和MCU之间建立什么样的连接?我目前使用的MCU是SPC560B64L7。
以上来自于谷歌翻译 以下为原文 Hello, if i wanted to program the MCU using SPC5 Connect via CAN, what kind of connection did I need to make between SPC5 Connect and the MCU? The MCU I currently using is SPC560B64L7. |
4个回答
我正在使用的当前IC有CAN收发器接口,唯一可用的FlexCAN是FlexCAN 4,SPC-5 Connect是绑定到特定的FlexCAN还是可以连接到任何可用的FlexCAN?
以上来自于谷歌翻译 以下为原文 The current IC that I'm using has CAN transceiver interface and the only FlexCAN available is FlexCAN 4, is SPC-5 Connect tied down to a specific FlexCAN or can it be connected to any FlexCAN that is available? |
你好黄,
不,它是FlexCAN0 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Wong , No , it is FlexCAN0 Best regards Erwan |
你好,Erwan,
谢谢回复。如果我想通过CAN对我的MCU进行编程,那么连接只是从SPC5-CONNECT到CAN0TX的CANC_RX和CANC_TX以及来自MCU的CAN0RX,是不是? 问候 皇 以上来自于谷歌翻译 以下为原文 Hello Erwan, Thanks for the reply. If i want to program my MCU via CAN, the connections are only CANC_RX and CANC_TX from SPC5-CONNECT to CAN0TX and CAN0RX from MCU, is it right? Regards Wong |
你好,Erwan,
对不起,这可能是因为我持怀疑态度,因为仅仅通过连接CAN RX和TX来编程MCU就太好了。如果我做出以下任何错误的假设,请纠正我。 SPC5-Connect在P3连接器上有CAN接口,我只需将SPC5-Connect的引脚21(CAN-H)和引脚22(CAN-L)连接到我的MCU(SPC560B64L7)FlexCAN0。忽略P3连接器中的所有其他引脚,例如SIN和SCK。感谢您的耐心和迄今为止提供的所有帮助。 问候 皇 以上来自于谷歌翻译 以下为原文 Hello Erwan, Sorry this may come out as me being skeptical, because programming a MCU just by connecting CAN RX and TX is just too good to be true. Please correct me if I make any of the assumptions below wrong. The SPC5-Connect has CAN interface at the P3 connector, I will just have to connect pin 21 (CAN-H) and pin 22 (CAN-L) of the SPC5-Connect to my MCU's (SPC560B64L7) FlexCAN0 only. Ignoring all the other pins from the P3 connector, such as SIN and SCK. Thank you for your patience and all the help provided thus far. Regards Wong |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1454 浏览 1 评论
2122 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2826 浏览 6 评论
5245 浏览 21 评论
362浏览 4评论
543浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
279浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
613浏览 3评论
515浏览 3评论
GMT+8, 2024-4-25 04:30 , Processed in 0.845079 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
