利用串行A/D转换器TLC549对输入信号电压源进行采集转换成数字信号给51单片机,经单片机进行数据处理后给1602液晶显示。
误差小于1%. #include #include #define uint unsigned int #define uchar unsigned char uchar LCD[6]; //电压数据转换成LCD1602液晶字符显示 uint Volt; ***it DO = P1^0; //时钟 ***it CS = P1^1; //片选 ***it CLK = P1^2; //数据输出 ***it RS = P2^0; //1602液晶数据/命令选择端 ***it RW = P2^1; //1602液晶读写端 ***it E = P2^2; //1602液晶使能端 // Function Prototypes void check_busy(void); void write_command(uchar com); void write_date(uchar date); void LCD_init(void); void string(uchar ad ,uchar *s); //void lcd_test(void); void delay(uint); void Volt_To_LCD1602(void); void delay_ms(uint xms); void Data_Conversion(void); uchar TLC549_ADC(void); /******************************************* LCD1602 Driver mapped as IO peripheral *******************************************/ // Delay // Delay void delay(uint j) { uchar i = 60; for(; j>0; j--) { while(--i); i = 59; while(--i); i = 60; } } // Test the Busy bit void check_busy(void) { do { P0 = 0xff; E = 0; RS = 0; RW = 1; E = 1; _nop_(); } while(P0 & 0x80); E = 0; } // Write a command void write_command(uchar com) { check_busy(); E = 0; RS = 0; RW = 0; P0 = com; E = 1; _nop_(); E = 0; delay(1); } // Write Data void write_date(uchar date) { check_busy(); E = 0; RS = 1; RW = 0; P0 = date; E = 1; _nop_(); E = 0; delay(1); } // Initialize LCD controller void LCD_init(void) { write_command(0x38); // 8-bits, 2 lines, 7x5 dots write_command(0x0C); // no cursor, no blink, enable display write_command(0x06); // auto-increment on write_command(0x01); // clear screen delay(1); } // Display a string void string(uchar ad, uchar *s) { write_command(ad); while(*s>0) { write_date(*s++); delay(100); } } //****************************************************// //函数名:delay_ms(uint xms) //函数功能:ms级延时函数 //***************************************************// void delay_ms(uint xms) { uint x,y; for(x=xms;x>0;x--) for(y=110;y>0;y--); } //***************************************************// //函数名称:TLC549_ADC() //函数功能:读取上一次A/D转换的数据,启动下一次A/D转换 //**************************************************// uchar TLC549_ADC(void) { uchar n, tmp; CS = 1; //CS置高,片选无效 CLK = 0; CS = 0; //CS置低,片选有效,同时DO输出高位 _nop_(); _nop_(); //适当延迟时间1.4us Setup Time for(n = 0; n < 8; n++) //串行数据移位输入 { tmp <<= 1; tmp |= DO; CLK = 1; //0.4us _nop_(); //CLK transition time Max 0.1us CLK = 0; //0.4us } CS = 1; //CS置高,片选无效 for(n = 17; n != 0; n--) _nop_(); //Next Coversion需要延迟17us return (tmp); } //****************************************// //函数名称ata_Conversion() //函数功能:电压换算 //*****************************************// void Data_Conversion(void) { uchar AD_Data; AD_Data = TLC549_ADC(); delay_ms(1000); Volt = 5.0 / 256 * AD_Data*1000; } void Volt_To_LCD1602(void) { Data_Conversion(); //电压换算并放大1000倍 LCD[0] = Volt/1000; //千位 LCD[1] = '.'; //小数点 LCD[2] = Volt/100%10; //百位 LCD[3] = Volt/10%10; //十位 LCD[4] = Volt%10; //个位 LCD[5] = 'V'; //字符V write_command(0x80+8); write_date(0x30+LCD[0]); write_date(LCD[1]); write_date(0x30+LCD[2]); write_date(0x30+LCD[3]); write_date(0x30+LCD[4]); write_date(LCD[5]); } int main() { //uint m; LCD_init(); delay(100); write_command(0x01); write_command(0x80); string(0x80,"Voltage:"); delay_ms(2000); while(1) { Volt_To_LCD1602(); } } 串行AD转换电路仿真.zip (71.36 KB ) |
10个回答
顶一个,挺好的
效果怎样?几位AD?
8位AD,0-5V电压测量误差很小,小于0.1%
8位做不到0.1%,8位的分辨率才0.4%
之前说错了,8位最大也只能做到大于0.4%,我这个反正小于1%没问题,你可以下载我上传的附件下来仿真下,看有什么问题没
我没有那个软件,玩不起来
哦哦,有带TLC549的A/D转换器的开发板就能实物调试了
我都玩16位,24位的,工作中都极少用8位了
哦哦,确实如果是在工作最好还是要用16位和24位的,我发现网上16位和24位A/D的中文资料很少耶,不知道是因为要在实际项目中运用,大家都不会分享出来?不像ADC0832,ADC0809,TLC549这些老版的8位A/D没什么太大实际项目应用价值,也适合初学者所以资料就多吗
资料应该还是比较多的,实际项目应用的,工程师当然不会那么容易就分享出来,其实有点点基础,ADI很多的ADC都有中文资料,操作一个ADC是很简单的事情,祝你天天向上
只有小组成员才能发言,加入小组>>
2970 浏览 9 评论
2687 浏览 16 评论
3212 浏览 1 评论
8426 浏览 16 评论
3770 浏览 18 评论
6950浏览 6评论
求助,请问MS51FB9AE带隙电压能作为侦测的基准电压吗?
7449浏览 3评论
6950浏览 3评论
支持UART-to-BLE透传的新唐NuTool – BLE ATCMD开发工具推荐
5798浏览 3评论
9370浏览 3评论
GMT+8, 2024-4-20 03:51 , Processed in 0.730995 second(s), Total 84, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
