大家好,
我想使用LIS3DH加速度计和带有ST Unico GUI的Steval-MK1109v2主板来记录加速度数据。 LIS3DH的数据表显示了可以测量高达5000Hz的带宽,这是我的振动器测量所需要的。 我使用Unico GUI将传感器配置为+ -2g和5000Hz模式。 我在振动器上尝试了一个160Hz的正弦信号并在Unico GUI上进行了在线FFT,但是在大约600Hz处出现了一个峰值,所以我看了一下.txt文件中的记录数据。我想添加一个时间路径,但认识到线路的数量根本不对。 我在大约3秒内记录了数据,但只得到了大约4000行。 ODR为5000Hz,预计可达16000线。 我测试了400Hz和1250Hz的模式,并且在线-FFT记录的数据都是正确的。 如果我之前使用0.0008s时间步长(1 / 1250Hz)记录5000Hz模式,它看起来是正确的...... 所以我的问题是: Unico GUI是否仅以高达1250Hz的速率记录数据(即使在5000Hz模式下),还是Unico GUI软件中的错误? 如果我查看GUI的错误在线FFT,其中显示600Hz但肯定只给出160Hz信号,它看起来就像那样。 我有点困惑。 谢谢你的帮助! 问候, 马库斯舒尔茨 #lis3dh-ODR-带宽UNICO贵 以上来自于谷歌翻译 以下为原文 Hello all, I want to use the LIS3DH accelerometer and a Steval-MK1109v2 Motherboard with the ST Unico GUI for logging Acceleration data. The datasheet of the LIS3DH shows the possibility to meassure a bandwidth up to 5000Hz, which i need for my shaker meassurements. I used the Unico GUI to configure the Sensor at +-2g and the 5000Hz mode. I tried a 160Hz sine signal at the shaker and made an online FFT at the Unico GUI, but there was shown a peak at about ~600Hz, so i took a look at the logged data in the .txt-file. I wanted to add a timepath but recognised that the number of the lines weren�t right at all. I logged data at about 3 seconds but got only roundabout 4000 lines. With a ODR of 5000Hz i expected up to 16000 lines. I tested the modes with 400Hz and 1250Hz and both online-FFT an logged data were right. If I use the 0.0008s timesteps (1/1250Hz) for the logged 5000Hz-mode before, it looks right... So theres my question: Does the Unico GUI only logg data with a rate up to 1250Hz(even in the 5000Hz mode) or could it be a bug in the Unico GUI software? If I take a look on the wrong online FFT of the GUI, where 600Hz are shown but surely only a 160Hz-signal is given, it looks like that. Im a little confused. Thanks for your help! Greetings, Markus Schulz #lis3dh-odr-bandwidth-unico-gui |
2个回答
嗨马库斯,
我也有同样的问题。您是否已在此方面取得进展或是否已切换到其他传感器?你愿意分享你的发现吗? 亲切的问候, 戴夫 以上来自于谷歌翻译 以下为原文 Hi Markus, I have the same question. Did you already make progress on this or have you switched to a different sensor? Would you be so kind to share your findings? Kind regards, Dave |
嗨戴夫,
你能不能试试最新版本的Unico软件和FW for STEVAL-MKI109V2。两者都可以找到 http://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-mki109w.html 我现在测试了,我能够以5.376 kHz的频率从LIS3DH记录数据。 以上来自于谷歌翻译 以下为原文 Hi Dave, can you please try the latest version of Unico software and FW for STEVAL-MKI109V2. Both you can find http://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-mki109w.html .I tested it right now and I'm able to log data from LIS3DH at 5.376 kHz. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1209 浏览 1 评论
1832 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1498 浏览 1 评论
2724 浏览 6 评论
4945 浏览 21 评论
293浏览 4评论
338浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
263浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
331浏览 3评论
345浏览 3评论
GMT+8, 2024-3-28 22:04 , Processed in 0.718921 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
