参考信号的目的是什么?
如何使用?建议的校准周期是多少? 此项目的网页上的此项目为空白。灵敏度,传感器的本底噪声是什么?真实的温度工作范围是什么,数据表上有错误?数据是否自动补偿超温? 温度超出范围是否有降额因子或表?数据是否记录了峰值数据或平均数据?数据是否加时间戳?如何与这些数据网络通信?每个数据都有唯一的IP地址吗? 每个人都有一些API理解的唯一ID?您可以在网络上放置多少个?您可以多快地轮询该单元的数据? 在系统中什么是延迟?可靠数据通信的距离限制是多少?如果距离很短,建议使用中继器吗?20dbm最大输入是否有内部保护?这些单元是否可以使用各种语言VB6,VB.net ,labview ???? 以上来自于谷歌翻译 以下为原文 What is the purpose of the reference signal? How is it utilized? What is the recommended calibration cycle? This item is blank on the web page for this unit. What is the sensitivity, the sensor's noise floor? What is the true temperature operating range, data sheet has an error on it? Is the data auto-compensated for over temperature? Is there a de-rating factor or table for temperatures exceeding the range? Is the data recorded peak data or average data? Is the data timestamped? How do you communicate with a network of these? Does each one have a unique IP address? Does each one have some unique id that the API understands? How many can you put on a network? How quickly can you poll the unit for data? In a system what is the latency? What is the distance limit for reliable data communications? If distance is short, are repeaters recommended? Is there any internal protection for the 20dbm max input? Will these units function with various languages VB6, VB.net, Labview???? |
2个回答
您的问题是:“这些单元是否可以使用各种语言VB6,VB.net,Labview ????”是的,我是LabView2010的用户库,以及LavView中的一些示例应用程序:DVB-T接收器,RDS接收器。
当您使用extallal dll调用Agilent SAL dll-s创建一个bas模块时,也可以在VB6中使用,但VB中的数学函数非常少,可以实现真正的良好和快速应用。 LabView更好。 以上来自于谷歌翻译 以下为原文 Your question was: "Will these units function with various languages VB6, VB.net, Labview????" Yes, I was made a user lib for LabView2010, and some example application in LavView: DVB-T receiver, RDS receiver. The using in VB6 also possible, when you create a bas module with extarnal dll calls to Agilent SAL dll-s, but there are very few math functions in VB for real good and quick application. LabView is more better. |
嗨Emp首先,你打算在哪里使用这些传感器?
我将能够帮助您解决一些问题。 问:您如何与这些网络进行通信? 答。 通过TCP / IP网络问:每个人都有唯一的IP地址吗? 答。 是。 您需要设置传感器网络。 问:每个人都有一些API理解的唯一ID吗? 答。 您在重新设置传感器网络时将设置唯一ID传感器管理服务器将帮助您快速设置我们的网络。 问:可靠数据通信的距离限制是多少? 答。 您打算使用哪种通讯媒体/方法? 问:20dbm最大输入有内部保护吗? Ans Yes Q这些单元是否可以使用各种语言VB6,VB.net,Labview ???? Ans API库和文档随传感器一起开发您自己的应用程序。 关心AKP 以上来自于谷歌翻译 以下为原文 Hi Emp First of all, where are you planning to use these sensors ??? I will be able to help you out on a few queries. Q. How do you communicate with a network of these? Ans. Over a TCP/IP network Q. Does each one have a unique IP address? Ans. Yes. You need to set up the sensor network. Q. Does each one have some unique id that the API understands? Ans. You will set the unique ID when you re setting up the sensor network Sensor Management Server will help you to set up our network in a flash. Q. What is the distance limit for reliable data communications? Ans. What communication media/ Method are you going to use? Q Is there any internal protection for the 20dbm max input? Ans Yes Q Will these units function with various languages VB6, VB.net, Labview???? Ans The API library and documentation comes alongwith the sensor to develop your own application. Regards AKP |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 03:27 , Processed in 1.126782 second(s), Total 72, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
