扫一扫,分享给好友
大家好,我打算使用EZBL对24FJ64GA10x产品进行远程更新。更确切地说,我的用户会从网站上下载BLOB文件,并在他们的设备上进行更新。我怀疑他们会喜欢使用一些命令行指令来做到这一点。还有什么共同点吗?方便和用户友好的Windows接口程序可用于此目的?非常感谢你的帮助
以上来自于百度翻译 以下为原文 Hi everybody, I plan to use EZBL for doing remote updates on 24FJ64GA10x based products. More precisely, my users would download a BLOB file from a website and make themselves their update on their device. I doubt they will appreciate using some command line instructions for doing this. Is there any convenient and user friendly Windows interface program available for that purpose ? Many thanks for your help Kelt |
4个回答
我有点晚了但是这里有几个选项:1。将必要的文件打包到包含命令行的批处理文件中。用户只需要解压缩文件夹并点击批处理文件。编辑:我猜用户仍然需要检查他连接到哪个端口,并在批处理文件2中编辑它。我不是开发人员/程序员,但我成功地将必要的EZBL组件(UART版本)封装到使用VisualStudio的Windows窗体应用程序中。非常基本。用户将看到什么新的端口弹出时,设备通过USB连接。选择该端口,选择固件文件(在我的情况下,它们是.rp文件),然后单击“更新”。
以上来自于百度翻译 以下为原文 I'm a little late but...here are a couple of options: 1. package the necessary files into a folder along with a batch file containing the command line. The user would just need to unzip the folder and click on the batch file. edit: I guess the user would still have to check what port he was connected to and edit that in the batch file 2. I am not a developer/programmer but I managed to wrap the necessary EZBL components(UART version) into a Windows Forms app using Visual Studio. Pretty basic. User will see what new port pops up when the device is connected via USB. Select that port, select the firmware file(in my case they are .trp files) and click Update. Attached Image(s) |
这里是一个更一般的版本,我所做的到目前为止。我用这个用MC2200 USB到UART串行转换器。这个版本查找固件.BL2文件。有一个波特选择选项,但我已经设置为现在不可见……为用户减少混乱。自动扫描打开端口。我对包含在installation.https://0901.nccdn.net/4_...2d3/.-EZBL-PC-App.zipor中的ezbl_tools.jar做了轻微的修改,或者安装程序包含新的固件文件……打开应用程序,插入设备并自动运行更新:https://0901.nccdn.n。ET/4~…L自动化PC-APP.ZIP
以上来自于百度翻译 以下为原文 Here is a more generic version of what I have done so far. I am using this with a MCP2200 USB to UART serial converter. This version looks for firmware.bl2 files. There is a baud select option, but I have it set to not visible for now...less confusion for users. Automatically scans for open ports. I made slight modifications to ezbl_tools.jar which is included in the installation. https://0901.nccdn.net/4_...2d3/My-EZBL-PC-App.zip Or an automated version where the installer includes the new firmware file...Open the app, plug in the device and the update runs automatically: https://0901.nccdn.net/4_...L-Automated-PC-App.zip |
你好TRP,抱歉打扰了…我正在开发基于AN1157的UART引导加载程序。我已经使用PICKIT3成功地将Bootloader代码加载到我的PIC24FJ128GB206中。P24QP能够检测到我的MCU,但是当我尝试写我的应用程序时,我得到了“运行时错误”。如果你有的话,请给我你的建议。谢谢,Muthu。
以上来自于百度翻译 以下为原文 Hello TRP, Sorry for intervening.. I am developing UART bootloader based on AN1157. I have successfully loaded Bootloader code to My PIC24FJ128GB206 using PICKIT3.Then, I tried to load My application.hex from P24QP software programmer. P24QP is able to detect MY MCU but I am getting "Runtime error" when I try to write My application.hex. Pleasse give me your suggestion if you have. Thanks, Muthu |
只有小组成员才能发言,加入小组>>
4824 浏览 9 评论
1829 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2954 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
362浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1797浏览 0评论
GMT+8, 2024-4-24 13:59 , Processed in 1.073434 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
