扫一扫,分享给好友
我正面临着FIFO模式下lis3dh加速度计的计时问题。目前我的ODR = 25 Hz并且我正在读取水印阈值= 30的FIFO。一旦我得到水印中断,我就会在5 Mhz读取196(32 * 3 * 2)个样本.Hence我在下一个ODR采样时间= 0.04秒(1/25)之前清除整个FIFO。
然而,在两分钟之后,我处于一秒的正偏移。这是由于加速度计时间的不准确吗? 我们的应用要求所有FIFO数据在2分钟内可用。 您能否告诉我们如何才能获得正确的定时数据? #lis3dh #mems #support#lis3dh 以上来自于谷歌翻译 以下为原文 I am facing timing issue with lis3dh accelerometer in FIFO mode.Currently my ODR=25 Hz and I am reading FIFO on watermark threshold=30.As soon as I get watermark interrupt I read 196 (32*3*2)samples at 5 Mhz.Hence I clear the entire FIFO before the next ODR sample time=0.04seconds(1/25). However after two minutes I am at an positive offset of one second.Is this due to inaccuracies in the accelerometer timing ? Our application requires that all the FIFO data to be available at precisely 2 minutes. Can you please tell us what can we do to achieve correct timed data. #lis3dh #mems #support #lis3dh |
1个回答
对于与MEMS相关的具体问题,请使用每个产品页面中提供的“在线支持”频道。
LIS3DH: http://www.st.com/internet/analog/product/250725.jsp 我正面临着FIFO模式下lis3dh加速度计的计时问题。目前我的ODR = 25 Hz并且我正在读取水印阈值= 30的FIFO。一旦我得到水印中断,我就会在5 Mhz读取196(32 * 3 * 2)个样本.Hence我在下一个ODR采样时间= 0.04秒(1/25)之前清除整个FIFO。 然而,在两分钟之后,我处于一秒的正偏移。这是由于加速度计时间的不准确吗? 我们的应用要求所有FIFO数据在2分钟内可用。 您能否告诉我们如何才能获得正确的定时数据? 以上来自于谷歌翻译 以下为原文 Please, for specific questions related to MEMS, use the ''ONLINE SUPPORT'' channel, available in every product page. LIS3DH: http://www.st.com/internet/analog/product/250725.jsp I am facing timing issue with lis3dh accelerometer in FIFO mode.Currently my ODR=25 Hz and I am reading FIFO on watermark threshold=30.As soon as I get watermark interrupt I read 196 (32*3*2)samples at 5 Mhz.Hence I clear the entire FIFO before the next ODR sample time=0.04seconds(1/25). However after two minutes I am at an positive offset of one second.Is this due to inaccuracies in the accelerometer timing ? Our application requires that all the FIFO data to be available at precisely 2 minutes. Can you please tell us what can we do to achieve correct timed data. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
503浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
561浏览 3评论
479浏览 3评论
GMT+8, 2024-4-20 09:27 , Processed in 0.896970 second(s), Total 69, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
