有没有人有关于1mW / 50MHz Ref源输出稳定性的信息。
我对输出功率变化感兴趣而不是特殊限制。我曾尝试用432A / 478A-H76热保护器测量1mW输出源,但我发现Ref输出功率从0.995到1.003mW不等(mount一直在 没有重新连接的相同位置)。 这是正常的表现吗? 从432A表开始,我已经将Vcomp和Vref电压从HP 3458A DVM中取出,并根据E4418B服务指南计算出这些电压值的功率输出。我应该在测量过程中考虑一些问题吗? 以上来自于谷歌翻译 以下为原文 Does anyone has information about 1mW/50MHz Ref source output stability. I'm interested about output power variation not the spesification limits. I have tried to measure 1mW output source with 432A/478A-H76 thermisor mount, but i have found that Ref putput power variying from 0.995 to 1.003mW (mount is all the time at the same position without re-connecting). Is it normal behaving? From 432A meter i have taken Vcomp and Vref voltages to HP 3458A DVM and calculated power output from those voltage values as E4418B service guide says. Should i take account some issues during that measurement process? |
1个回答
E4418B中1 mW参考的规格包括短期和长期稳定性。
在23摄氏度+/- 3摄氏度规格范围内,您的测量值远低于+/- 0.5%。 因此它通过了校准测试。由于E4418B的1 mW参考信号,热敏电阻安装座及其电缆以及您正在使用的432A / 3458A的温度和时间不稳定性,您将在一段时间内获得信号电平的一些变化。 所有这些变量都应包含在进行校准时使用的不确定度分析中。但你没事。 你在规范范围内。 以上来自于谷歌翻译 以下为原文 The specifications for the 1 mW reference in the E4418B include short term and long term stability. Your measured value is well within the +/-0.5% over the 23 degree C +/- 3 degrees C specification. So it passes it calibration test. You will get some variation in signal levels over time due to temperature and time instabilities in both the E4418B's 1 mW reference signal, the thermistor mount and its cable, and the 432A/3458A you are using. All of these variables should be included in the uncertainty analysis you are using when making this calibration. But you are fine. You are within spec. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 09:48 , Processed in 1.056685 second(s), Total 89, Slave 79 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
