用xilinx sdk 中 Xtime_GetTime 函数测得读取DMP速率仅为 67 Hz ,但是 在Processing中跑的正常,所以不知道为什么达不到200 Hz ,DMP 初始化代码如下,求告知问题所在,感激涕零 !
int Mpu9250_DMP_Init(void) { uint8_t dmpUpdate[16], j; uint16_t pos = 0; uint16_t fifoCount; uint8_t fifoBuffer[128]; uint8_t mpuIntStatus; // Reset MPU9250 Reset(); usleep(3000); // wait 3ms after reset // disable sleep mode Set_Sleep_Enabled(false); //Selecting user bank 16 Set_MemoryBank(0x10, true, true); //Selecting memory byte 6... Set_MemoryStartAddress(0x06); hwRevision = Read_MemoryByte(); printf("hwRevision is %dn",hwRevision); //Resetting memory bank selection to 0... Set_MemoryBank(0, false, false); // check OTP bank valid otpValid = Get_OTPBankValid(); //the reg 0x00 is different 9250 & 9250 printf("otpValid is %dn",hwRevision); xgOffsetTC = Get_XGyroOffsetTC(); ygOffsetTC = Get_YGyroOffsetTC(); zgOffsetTC = Get_ZGyroOffsetTC(); printf("xgOffsetTC is %d.n",xgOffsetTC); printf("ygOffsetTC is %d.n",ygOffsetTC); printf("zgOffsetTC is %d.n",zgOffsetTC); //Setting slave 0 address to 0x7F... Set_SlaveAddress(0,0x7f); //Disabling I2C Master mode... Set_I2CMasterModeEnabled(false); //Setting slave 0 address to 0x68 (self)... Set_SlaveAddress(0,0x68); //Resetting I2C Master control... Reset_I2CMaster(); usleep(200); // load DMP code into memory banks if(Write_ProgMemoryBlock(dmpMemory, MPU9250_DMP_CODE_SIZE,0,0,1)) { //Success! DMP code written and verified. //write DMP configuration if (Write_ProgDMPConfigurationSet(dmpConfig, MPU9250_DMP_CONFIG_SIZE)) { //Success! DMP configuration written and verified. //Setting clock source to Z Gyro... Set_Clock_Source(MPU9250_CLOCK_PLL_ZGYRO); //Setting DMP and FIFO_OFLOW interrupts enabled... Set_IntEnabled(0x12); //Setting sample rate to 200Hz... Set_Rate(4); // 1khz / (1 + 4) = 200 Hz //Setting external frame sync to TEMP_OUT_L[0]...; Set_ExternalFrameSync(MPU9250_EXT_SYNC_TEMP_OUT_L); //Setting DLPF bandwidth to 42Hz... Set_DLPFMode(MPU9250_DLPF_BW_42); //Setting gyro sensitivity to +/- 2000 deg/sec... Set_FullScaleGyroRange(MPU9250_GYRO_FS_2000); //Setting DMP configuration bytes (function unknown)... Set_DMPConfig1(0x03); Set_DMPConfig2(0x00); //Clearing OTP Bank flag... Set_OTPBankValid(false); //Setting X/Y/Z gyro offset TCs to previous values... Set_XGyroOffsetTC(xgOffsetTC); Set_YGyroOffsetTC(ygOffsetTC); Set_ZGyroOffsetTC(zgOffsetTC); //Writing final memory update 1/7 (function unknown)... for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]); Write_MemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1],true,false); //Writing final memory update 2/7 (function unknown)... for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]); Write_MemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1],true,false); //Resetting FIFO... Reset_FIFO(); //Reading FIFO count... fifoCount = Get_FIFOCount(); //Reading FIFO data... ReadFIFO_S(fifoBuffer, fifoCount); //Setting motion detection threshold to 2... Set_MotionDetectionThreshold(2); //Setting zero-motion detection threshold to 156... Set_ZeroMotionDetectionThreshold(156); //Setting motion detection duration to 80... Set_MotionDetectionDuration(80); //Setting zero-motion detection duration to 0... Set_ZeroMotionDetectionDuration(0); //Resetting FIFO... Reset_FIFO(); //Enabling FIFO... Set_FIFOEnabled(true); //Enabling DMP... Set_DMPEnabled(true); //Resetting DMP... Reset_DMP(); //Writing final memory update 3/7 (function unknown)... for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]); Write_MemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1],true,false); //Writing final memory update 4/7 (function unknown)... for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]); Write_MemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1],true,false); //Writing final memory update 5/7 (function unknown)... for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]); Write_MemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1],true,false); //Waiting for FIFO count > 2... while((fifoCount = Get_FIFOCount()) < 3) ; //Reading FIFO data... ReadFIFO_S(fifoBuffer, fifoCount); //Reading interrupt status... mpuIntStatus = Get_IntStatus(); //Reading final memory update 6/7 (function unknown)... for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]); Read_MemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1]); //Waiting for FIFO count > 2... while ((fifoCount = Get_FIFOCount()) < 3) ; //Reading FIFO data... ReadFIFO_S(fifoBuffer, fifoCount); //Reading interrupt status... mpuIntStatus = Get_IntStatus(); //Writing final memory update 7/7 (function unknown)... for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]); Write_MemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1],true,false); //Mpu9250_WriteReg_R(MPU9250_RA_FIFO_EN,0x00); //default 0x00 //DMP is good to go! Finally. //Disabling DMP (you turn it on later)... Set_DMPEnabled(false); //Setting up internal 42-byte (default) DMP packet buffer... dmpPacketSize = 42; /*if ((dmpPacketBuffer = (uint8_t *)malloc(42)) == 0) { return 3; // TODO: proper error code for no memory }*/ //Resetting FIFO and clearing INT status one last time... Reset_FIFO(); Get_IntStatus(); } else { //ERROR! DMP configuration verification failed. return 2; // configuration block loading failed } } else { //ERROR! DMP code verification failed. return 1; // main binary block loading failed } return 0; // success } |
3个回答
我没仔细看代码,但是我用逻辑分析仪查看MPU9250的IIC时发现,每次读取FIFO之前都会清空重置FIFO,这部分浪费了很多时间,大概就是整个读取过程,真正在读取FIFO的时间只占1/7;目前不知道解决办法
抱歉,之前我说的那个问题我已经发现是正常的了,我没加延迟 所以那一大段“无用数据”其实是在检查FIFO中有无数据
只有小组成员才能发言,加入小组>>
GMT+8, 2024-3-29 03:29 , Processed in 0.817599 second(s), Total 72, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
