是否可以在UDBs内部实现存储卡?没有什么大的只有大约32 kb。UDB是易失性还是非易失性?
以上来自于百度翻译 以下为原文 is it possible to implement a memory card inside UDBs? not anything big just approximately a 32KB. also is the UDBs volatile or non-volatile? |
8个回答
你有可能在Flash中做到这一点。
Flash有100000个周期擦除限制,但增加了磨损均衡算法 它可以延长R/W寿命。 问候,Dana。 以上来自于百度翻译 以下为原文 You could potentially do it in FLASH. FLASH has a 100,000 cycle erase limit, but adding a wear leveling algoritim to it could extend R/W lifetime. Regards, Dana. |
看,这就是问题所在。我不想使用外部SD存储卡来节省空间,这就是为什么我问UDBs内部的实现……有什么想法吗?
以上来自于百度翻译 以下为原文 see this is the problem. I don't want to use an external SD memory card to save space that's why I am asking about the implementation inside the UDBs.....any thoughts? |
由于PSoC通常不能从您的PCB中移除,所以您的问题可以重新表述为
如何在PSoC中存储数据。 它取决于查看EEPROM模块是否满足您的需要所需的可变数据量,所有所需的常量内存可以驻留在Flash中,并在编程时与代码一起写入。EEPROM区域/ MODUL必须为您的需要定制,您可以使用它作为一个内存区域,其中数据被写入到您的控制下,并像指针一样使用任何其他内存区域读取。 当你对我们的要求(大小、写的频率、写期间的功率损失的预防、每次请求写入的数据量等)有一点明确时,我们可能会为你找到解决方案。 鲍勃 以上来自于百度翻译 以下为原文 Since a PSoC usually is not removable from your PCB your question can be re-formulated as How to store Data within a PSoC. It depends on the amount of changeable data required to see whether the EEProm-module will serve your needs, all required constant memory can reside in flash and is written together with the code at programming-time. The EEProm area/modul has to get customized for your needs and you may use it as an area of memory where data is written to under your control and read from like any other memory area using pointers. When you are a bit more specific about ýour reqirements (Size, frequency of writing, precautions against power-loss during write, amount of data written at each request etc) we probably may find a solution for you. Bob |
UDB数组将不支持32 K,因为您可以看到它的基本结构
附图。其中只有少量的内存,用于FIFO,配置。 寄存器等。 你唯一的选择是在flash程序空间中创建一个SD等价物, 并采用磨损均衡算法。 问候,Dana。 UDB阵列 29.4 K 以上来自于百度翻译 以下为原文 The UDB array would not support 32K, as you can see its basic structure in attached pic. There is only small amounts of memory in them, for FIFO, config registers, etc.. Your only alternative is to create an SD equivalent in FLASH program space, and use wear leveling algorithim. Regards, Dana.
PSoC 5附带高达256 KB的闪存,所以您的32 KB需求很容易获得,
除非你的代码大小给你带来了局限性。 一个例子-HTTP://www-Dead DeAccess .COM/PROSTS/FFSHFLASHFIL.HTML 问候,Dana。 以上来自于百度翻译 以下为原文 PSOC 5 comes with up to 256 KB Flash, so your 32KB requirement easily achived, unless your code size brings you right up to part limitations. One example - http://www.embedded-access.com/products/ffs_flash_file.html Regards, Dana. |
一个问题引出另一个问题:在PSoC 5系列数据表中,我发现Flash是“高达256 KB”,我发现一些PSoC 5芯片只有64KB…所以我打算买这个工具包:HTTP://www. CyPress?RID=51577……请告诉我它是否有256KB闪光灯?
以上来自于百度翻译 以下为原文 one question leads to another :) in the PSOC 5 family datasheet I found that it says FLASH is "up to 256 KB" and I found some PSOC 5 chips with only 64KB... so I'm planning to buy this kit http://www.cypress.com/?rID=51577....can you please tell me whether it has 256KB flash? |
它有256KB闪存,看这里HTTP://wwwyCysP.com/?MPN=CY8C5868 AXI-LP035
鲍勃 以上来自于百度翻译 以下为原文 It has 256kB flash, look here http://www.cypress.com/?mpn=CY8C5868AXI-LP035 Bob |
谢谢你们(和女孩们):你们是最好的
以上来自于百度翻译 以下为原文 thanks guys (and girls) :) you are simply the best |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
324浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-25 03:50 , Processed in 0.652660 second(s), Total 51, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
