我面临着为Spartan XL(XCS30XL-4PG240C)创建VHDL设计的问题。
最近,我收到了一个项目并被告知转换安装的原理图电路 将Spartan XL(XCS30XL-4PG240C)转换为VHDL格式。 今天,我安装了支持Spartan XL系列的ISE Classics,但未能选择VHDL作为设计流程。 后来,我在网上查了一下,发现与ISE WebPACK不同,第三方工具需要使用ISE Classics完成设计输入。 是否有任何建议,我可以在网上找到任何免费看到我有限的预算。 如果有人做了一件熟悉的工作,就像我现在要做的那样,我也想得到你的意见。 感谢您的帮助。 祝你今天愉快。 以上来自于谷歌翻译 以下为原文 I'm facing problem creating VHDL design for Spartan XL(XCS30XL-4PG240C). Recently, I received a project and been told to convert a schematic circuit installed in a Spartan XL(XCS30XL-4PG240C) into VHDL fromat. Today, I installed ISE Classics which supports Spartan XL Family but failed to select VHDL as it's design flow. later, I checked it online snd found out that unlike the ISE WebPACK, third party tools are required to accomplish design entry using ISE Classics. Is there any suggestion where I can find any of that online for free seeing that I have limited budget. If anyone had done a familiar work just like what I'm going to do from now on,I would like to have your opinion too. Thanks for your help in advance. Have a nice day. |
2个回答
嗨,
你可以尝试一件事。 一些(较旧的)书籍带有学生版ISE4.2。 也许(运气好的话)他们还提供HDL综合所需的第三方综合工具,就像完整版本一样。 (那是Synopsys FPGA编译器,在过去)。 你需要为这样一个过时的设备设计什么样的命运? 是打算改进旧设计并将其重新加载到旧板上,还是旧设计应该在更实际的设备中运行? 在后一种情况下,您不需要旧工具。 原理图纸是基于或已在您的计算机上可用。 (哪种格式?EDIF,ECS-Schematic ......?) 有一个很好的综合 Eilert 以上来自于谷歌翻译 以下为原文 Hi, there may be one thing you can try. Some (older) books came with a student version of ISE4.2. Maybe (with some luck) they also provide the third party synthesis tools required for HDL synthesis, like the full versions did. (That was Synopsys FPGA Compiler, in the old days). What bad fate makes you need to design for such an outdated device? Is the intention to improve the old design and reload it into the old board, or shall the old design run in a more actual device? In the later case you don't need the old tools. Are the schematics paper based, or already available on your computer. (Which format? EDIF, ECS-Schematic...?) Have a nice synthesis Eilert |
eilert写道:
你需要为这样一个过时的设备设计什么样的命运? 开玩笑吧! 我试图这样做的问题是不支持工具或芯片。 另外,我想知道“经典”复古工具(包括Synopsys工具和IMPACT)是否可以在现代操作系统上运行。 如果这是一次学习/培训练习,我建议您定位S3设备。 有来自第三方的便宜的演示/评估S3板,你可以在许多当前的操作系统平台上获得webpack(包括IMPACT,synth,sim)的支持。 如果这是一个改造 - 不再生产的产品的逆向工程工作,那么方便的方法是简单地使用原始工具和设计数据库(它们被存档,对吧?)。 同样,您可能必须找到要安装和运行工具的Win95机器。 如果变化适度,那么将设计转换(原理图到HDL)添加到项目中比在原理图中保留更多的工作和风险更大。 首先,原理图比HDL更容易设计评论。 还有一件事 - 如果您最终继续进行转换,您是否有选择VHDL与Verilog的自由裁量权? 如果是这样的话,你可能会转向Verilog,其他条件相同。 将来,请告诉您的同事,您的治疗师禁止您接受任何比Spartan 3更老的技术。 另一方面,如果有许多类似的古代设计需要更新,那么你将成为公司的大师,这项任务非常可恶,任何其他任何人都不会来到它附近。 对其他人挖掘类似项目的恐惧将使您立即成为公司的重要资源。 你将学到一种其他人没有或想拥有的技能,这使你不可或缺。 就业保障! (那是一线希望!) - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 eilert wrote: What bad fate makes you need to design for such an outdated device? No kidding! The problem I see with trying to do this is there's no support for either the tools or the silicon. Plus I wonder if the 'classic' vintage tools (incl the Synopsys tool, and IMPACT) would run on a modern OS. If this is a learning/training exercise, I would suggest targeting an S3 device. There are cheap demo/eval S3 boards from 3rd parties, you get support for webpack (incl IMPACT, synth, sim) on a number of current OS platforms. If this is a retrofit - reverse-engineer job for a product no longer in production, then the expedient approach is to simply use the original tools and design database (they were archived, right?). Again, you might have to find a Win95 machine on which to install and run the tools. If the changes are modest, it's more work and more risk to add design conversion (schematic to HDL) to the project than to stay in schematics. For one thing, schematics are a heckuva lot easier to design review than HDL. And another thing -- do you have discretion for choosing VHDL vs. Verilog, if you end up going forward on the conversion? If so, you might steer yourself toward Verilog, all else being equal. In the future, tell your colleagues that your therapist has forbidden you from taking on any technology older than Spartan 3. On the other hand, if there are a number of similar ancient designs in need of updates, then you will become the company guru on a task that is so odious that no-one else will come anywhere near it. The fear that others have of dredging up a similar project will make you, instantly, a critical resource to the company. You will have learned a skill that no-one else has or wants to have, and that makes you indispensable. Job security! (that's the silver lining!) - Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-18 07:16 , Processed in 0.825331 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
