你好,
我需要帮助才能使用X-NUCLEO-CCA02M1和STEVAL-MKI155V3将X-CUBE-MEMSMIC的4麦克风架构扩展到6个麦克风。我附加了修改后的BSP驱动程序.c和.h文件。同样在audio_application.h我改变了号码。将麦克风设置为6.我试图为麦克风M5和M6配置SPI3。我看到SPI1和SPI3的slave选择是相同的,因为在这种情况下没有使用slave select,我知道这不应该是一个问题。你能不能让我知道我应该调查哪些部分代码才能让它适用于6个麦克风。我也试图增加PDM缓冲区但没有成功。我看到PDM数据在所有4个麦克风的范围内都可用,但是由于我的部分代码的变化,数据没有被记录。除了x_nucleo_cca02m1_audio_f4 BSP驱动程序之外,我应该考虑将其扩展到6个麦克风架构。 谢谢, 拉姆亚 以上来自于谷歌翻译 以下为原文 Hello, I need help with regard to extending the 4 microphone architecture of X-CUBE-MEMSMIC to 6 microphones using X-NUCLEO-CCA02M1 and STEVAL-MKI155V3. I have attached the modified BSP driver .c and .h files. Also in audio_application.h I have changed the no. of microphones to 6. I have tried to configure SPI3 for microphones M5 and M6. I see that slave select for both SPI1 and SPI3 are the same and since the slave select is not being used in this case, I know this shouldnt be a problem. Can you please let me know which all part of the code should I look into to get it working for 6 microphones. I have also tried to increase the PDM buffer but have not been successful. I see that PDM data is available on scope on all the 4 microphones but due to changes from my part of the code the data is not being recorded. Apart from the x_nucleo_cca02m1_audio_f4 BSP driver which part I should look into to extend the same to 6 microphone architecture. Thanks, Ramya |
2个回答
en.X-CUBE-MEMSMIC1
我想将此添加到stm32cube但是说这个版本不适用于此stm32cube版本 STM32CubeExpansion_MEMSMIC1_V1.3.0 STM32Cube_FW_F4_V1.12.0 以上来自于谷歌翻译 以下为原文 en.X-CUBE-MEMSMIC1 I want to add this to stm32cube but say this verison is not for this stm32cube release STM32CubeExpansion_MEMSMIC1_V1.3.0 STM32Cube_FW_F4_V1.12.0 |
你好
http://uploads.im/ZXPmL.png ''不适用于此版本 STM32CubeMX'' 请注意 那个Ahrovan 以上来自于谷歌翻译 以下为原文 Hi http://uploads.im/ZXPmL.png ''doesn't apply to this version of STM32CubeMX '' please note thx Ahrovan |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1392 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2802 浏览 6 评论
5180 浏览 21 评论
351浏览 4评论
486浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
537浏览 3评论
466浏览 3评论
GMT+8, 2024-4-18 23:10 , Processed in 0.793421 second(s), Total 70, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
