大家好!注意,我最近重新启动了MPLABX IDE v3.45I,重新启动后,我无法构建任何项目。在顶部选择任何构建或调试按钮都不会导致任何操作(也不会产生任何错误)。我不确定为什么会这样。**一些附加的评论:重新启动后,我在打开旧项目时也遇到了问题。在读取项目的“configurations.xml”文件时,将产生错误“在prolog中不允许内容”。显然这是过去的一个问题。原始文件已附加。***可能有重要注释:我还删除了持久性文件(位于~userAppDataRoamingmplab_idedevv3.45下)以重置IDE的窗口配置,在重新启动后该窗口配置也发生了更改。
以上来自于百度翻译 以下为原文 Hi Everyone! :) *Note I have MPLABX IDE v3.45 I recently restarted my computer, and upon rebooting I could not build any of my projects. Selecting any of the build or Debug buttons at the top results in no action (neither is there any error generated). I am not sure why this is the result. **Some additional comments: Upon restarting I also had problems opening old projects. The error "Content is not allowed in prolog" would be produced upon reading the project's "configurations.xml" file. Apparently this has been a problem in the past. The original file is attached. ***Possibly important comment: I also deleted the persistence files (located in under ~userAppDataRoamingmplab_idedevv3.45) to reset the IDE's window configuration, which had also changed after restarting. Attachment(s) configurations.c (11.37 KB) - downloaded 1 times |
5个回答
请查找解决问题的链接
以上来自于百度翻译 以下为原文 Hi Please look link for solution of your problem http://www.microchip.com/forums/m782572.aspx -- TS9 |
谢谢TS9。但是在那个链接中似乎没有一个解决方案。另外,我的问题尤其是在第一个帖子中附带的配置文件.xml文件。(扩展是由于微芯片论坛限制)。
以上来自于百度翻译 以下为原文 Thank you TS9. But there doesn't appear to be a solution in that link. Plus, my problem is particularly with the configurations.xml file attached in the first post. (The extension is (*.c due to Microchip forum restrictions). |
解决:在删除/移除项目选项卡中的旧项目(损坏的项目)之后,我能够解决无法构建项目的问题。
以上来自于百度翻译 以下为原文 Resolved: After deleting/removing the old projects (corrupted projects) in the projects tab, I was able to resolve the issue of not being able to build projects. |
与MPLAB X 3.5有同样的问题;关闭所有的项目,除了我正在做的一个项目。
以上来自于百度翻译 以下为原文 Had the same issue with MPlab X 3.5; closing all the projects except the one I was working on did the trick. |
只有小组成员才能发言,加入小组>>
4779 浏览 9 评论
1815 浏览 8 评论
1734 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2941 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2043 浏览 5 评论
423浏览 1评论
1101浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
345浏览 0评论
253浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1751浏览 0评论
GMT+8, 2024-3-29 17:34 , Processed in 0.946350 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
