我正在努力解决一个新手问题,我正在创建一个简单的键盘库(我知道XC8不支持通过MPLAB创建库项目),我用Ma.C KP.C KP.H创建了一个测试项目,在H文件中有一些定义。我使用KP.C中定义的编译错误而不是MIN .CMPLAB V3.45 XC8 V1.40提前感谢。编辑:键盘库。C:36:错误:(192)未定义的标识符“TrISB”(908)退出状态=1NbPosi/MaFaMeCurrime.MK:99:目标“构建/默认/调试/键盘库”的配方。P1’失败[ 2 ]:离开目录'D//MPLA/KEAMPIDLI.x'NbPosi/MaFaMeCurrase.MK: 84:目标'Buffic CONF 'FultEdvest[[ 1 ] ]:离开目录'D//MPLANS/MPLAB /键盘LIB .x'NbPosi/MaFix.IMP.MK:39:目标''.Buff-IMPL 'FuleDebug [2 ] ]:*Buff/Buff/Debug /键盘LIB[1]错误[1]使[1 ]:**[Buffic CONF]错误2::**[构建IMPL]错误2Bug失败(退出值2,总时间:1s)
以上来自于百度翻译 以下为原文 I am struggling with a newbie problem, i am creating a simple Keypad library (i know xc8 doesnt support creating library project through MPLAB), i have created a test project with main.c KP.c KP.h with some defines in the .h file. i get a compilation error using those defines in KP.c but not in main.c MPLAB v3.45 XC8 v1.40 Thanks in advance. EDIT: KeyPad Library.c:36: error: (192) undefined identifier "TRISB" (908) exit status = 1 nbproject/Makefile-default.mk:99: recipe for target 'build/default/debug/KeyPad Library.p1' failed make[2]: Leaving directory 'D:/Projects/MPLAB/KEYPAD LIB.X' nbproject/Makefile-default.mk:84: recipe for target '.build-conf' failed make[1]: Leaving directory 'D:/Projects/MPLAB/KEYPAD LIB.X' nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed make[2]: *** [build/default/debug/KeyPad Library.p1] Error 1 make[1]: *** [.build-conf] Error 2 make: *** [.build-impl] Error 2 BUILD FAILED (exit value 2, total time: 1s) |
4个回答
如果给出更详细的信息,比如什么编译错误,那么您更有可能收到有用的答案。
以上来自于百度翻译 以下为原文 You are more likely to receive useful answers if you give a little more detail, such as what compilation errors? |
C文件可能被忽略包括XC.H。
以上来自于百度翻译 以下为原文 KeyPad Library.c:36: error: (192) undefined identifier "TRISB" The C file probably neglected to include xc.h. |
FIY:对于版本3.50,现在可以在IDE.Jeff中用XC8构建库。
以上来自于百度翻译 以下为原文 FYI: As of version 3.50, you can now build libraries with XC8 in the IDE. Jeff. |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-19 08:41 , Processed in 1.036991 second(s), Total 73, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
