我想知道Agilent E5339A探头是否能够在-3V .. + 3V电压阈值范围内捕获比使用逻辑分析仪更高的电压。
我还想知道您是否可以重新映射从Mictor或Samtec PCB测试连接器占用空间捕获的信号,包括接地焊盘。 我知道有来自Altera和Xilinx的FPGA动态探针系统,例如 B4655A和B4656A,但我想知道我是否可以使用逻辑分析仪手动执行此操作。 以上来自于谷歌翻译 以下为原文 I was wondering if the Agilent E5339A probe would be able to capture higher voltages than the ones inside its -3V..+3V voltage threshold range possibly with the help of the used logical analyzer. I would also want to know if you could remap the signals, including the ground pads, captured from a Mictor or Samtec PCB test connector footprint. I know that there are FPGA dynamic probe systems from Altera and Xilinx, e.g. B4655A and B4656A, but I would like to know if I can do this manually using the Logic Analyzer. |
1个回答
E5339A专为低压信号而设计。
它与E5346A具有相同的占位面积,但内部分隔器较小。 如果过载,可能会损坏分析仪。 您可以在占位面积内,甚至跨脚印重新排序信号引脚。 您可以使用'时钟'信号作为数据。 接地信号始终是接地信号,不应连接到信号。 人 以上来自于谷歌翻译 以下为原文 The E5339A is designed specifically for lower-voltage signals. It has the same footprint as, but a smaller internal divider than, the E5346A. If you overdrive it, you could damage the analyzer. You can reorder the signal pins within a footprint, or even across footprints. You can use 'clock' signals as data. Ground signals will always be grounds and should not be connected to signals, ever. Al |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 02:58 , Processed in 1.206532 second(s), Total 69, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
