发 帖
原厂入驻New
发烧友10周年庆典,全网超值优惠来袭!千元现金券,下单抽奖赶紧参与》》
[问答] 用echoserver示例无法ping FPGA
118 xilinx Spartan FPGA
分享
大家好,
我正在使用spartan 3e并使用echo示例测试以太网通信,但是在运行示例后我无法ping通FPGA
我使用Hub连接FPGA和Pc,是否会导致问题?
最好的祝福,
罗伊
以上来自于谷歌翻译
以下为原文
Hi, all,
I am using spartan 3e and test the ethernet communication with echo example, but I can not ping the FPGA after the example running.
I am using a Hub to connect the FPGA and Pc, does it cause the issue?
Best Regards,
Roy
2019-5-21 10:45:38   评论 分享淘帖 邀请回答
4个回答
我有同样的问题。
我怀疑它是集线器,但您可能想尝试使用交叉电缆直接连接。
我怀疑这个问题与中断有关。
我看到PHY连接器上的LED闪烁并发出ping请求,但我没有看到任何响应。
Wireshark表示FPGA没有应答ARP请求,所以我怀疑没有收到数据包。
我会告诉你我发现了什么 - 希望其他人已经越过这座桥了?
祝你好运
以上来自于谷歌翻译
以下为原文
I am having the same issue.  I doubt it's the hub, but you may want to try connecting directly using a crossover cable.
I suspect that that the problem has something to do with interrupts.  I see the LED on the PHY connector blink with the ping requests, but I don't see any response.  Wireshark indicates that the FPGA is not answering ARP requests, so I suspect that NO packets are being received.
I'll let you know what I find - hopefully someone else has crossed this bridge already?
Good Luck
2019-5-21 10:59:39 评论
举报
嗨,谢谢你的回复,
我已经弄清楚了,我没有ping它,只是使用了一些软件工具来接收和发送数据到FPGA,它的工作原理。
但是,使用交叉电缆可以使传输更快更可靠(对于UDP)。
问题是速率,它应该是10Mbps,但基于测试,只有16bit / ms .......
以上来自于谷歌翻译
以下为原文
Hi, Thank you for your reply,
I already figured it out, I did not ping it, just used some software tools to receive and send data to FPGA, it works. But, using crossover cable makes the transmission faster and more reliable.(for UDP).
The issue is the rate, it is supposed to be 10Mbps, but based on the test,, just 16bit/ms.......
2019-5-21 11:16:16 评论
举报
你好cfgmgr,
我面临着同样的问题......你找到了解决方案了吗?
我正在使用Spartan 6 sp601评估套件,我的设计基于xapp1041,微处理器作为处理器......
thanx提前..
以上来自于谷歌翻译
以下为原文
hello cfgmgr,
i'm facing the same problem...did you find a solution already?
I'm using Spartan 6 sp601 evaluation kit and my design is based on xapp1041 with microblaze as a processor...
thanx in advance..
2019-5-21 11:34:05 评论
举报
是的,我做了,虽然我的硬件是S3E入门套件,而不是基于Spartan-6的系统。
不过,您可能对此主题感兴趣
http://forums.xilinx.com/xlnx/board/message?board.id=XLNXBRD&message.id=2334#M2334
Hopefull,您将能够使用该信息来帮助您。
祝你好运!
以上来自于谷歌翻译
以下为原文
Yes, I did, although my hardware was an S3E starter kit, and not a Spartan-6 based system.  Nevertheless, you might be interested in this thread
Hopefull, you will be able to use that information to help you along.
Good Luck!
2019-5-21 11:45:40 评论
举报
只有小组成员才能发言,加入小组>>
38个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /10 下一条
快速回复 返回顶部 返回列表
