大家好,我面临着以下问题:MCU:PIC24FJ256GA406Programmer:PICKIT 3During MPLAB X IDE 3.5中的编程过程,在PICKIT3日志窗口中显示以下消息:“目标设备ID(0x0)是无效的设备ID。请检查到目标设备的连接“MCU是单独构建的,除了推荐的最小连接外,没有外部组件(用户手册第2.0章,图2-1))——配置位(FICD)设置为PGx1(连接到PGEC1和PGED1)——我们还尝试了默认的PGx3(与PGEC3和PGED3连接)——Internal振荡器选择PICKit编程器电源目标设置为3.0V(无外部电源)-外部3.0V电源(PICKit电源目标未选中)-故障单片机(2次更换)我们欢迎任何有用的建议。预先感谢你。最好的问候。
以上来自于百度翻译 以下为原文 Hello Everyone, I am facing with the following problem: MCU: PIC24FJ256GA406 Programmer: PICKIT 3 During the programming process in the MPLAB X IDE 3.5 the following message appears in the PICKIT3 log window: "Target Device ID (0x0) is an Invalid Device ID. Please check your connections to the Target Device." - The MCU is built separately with no external components except the recommended minimum connections (User manual Chapter 2.0, Figure 2-1) - The Configuration Bits (FICD) are set to PGx1 (connected to PGEC1 and PGED1) - We tried out the default PGx3 also (with PGEC3 and PGED3 connected) - Internal oscillator selected PICKit programmer Power Target set to 3.0V (with no external Power) - External 3.0V power supply (PICKit power target unchecked) - Failed MCU out of the question (2 times replaced) We are welcome any useful recommendations. Thank you in advance. Best Regards. |
4个回答
你有所有的VDD和VSS管脚连接吗?在PGC/PGD/MCLR上是否有任何组件,如果是这样的话,可能是问题所在。
以上来自于百度翻译 以下为原文 Do you have all Vdd and Vss pins connected? Do you have any components on PGC/PGD/MCLR if so that could be the problem. |
MCU是独立建造的,除了推荐的最小连接外,没有外部组件。你核实过Vcc吗?
以上来自于百度翻译 以下为原文 The MCU is built separately with no external components except the recommended minimum connections Does this include all the required capacitors? Did you verify Vcc? |
显然这个问题已经解决了,但是OP在别人的主题中公布了他们的解决方案。http://www..hip.com/for./FindPost/969800
以上来自于百度翻译 以下为原文 Apparently this issue has been solved, but the OP posted their solution in someone else's topic. http://www.microchip.com/forums/FindPost/969800 |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-20 08:54 , Processed in 1.161810 second(s), Total 69, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
