HII已经在一些项目上使用了RN4020的MLDP模式,并取得了一些成功。我现在正在考虑开发一个简单的android应用程序来连接到RN4020,使用MLDP发送接收小块的数据。为了在项目上取得领先,我从微芯片网站下载了MLDPTErminal8.apk。这对于手机来说可以正常工作,我可以从RN4020模块发送和接收数据,该模块连接到运行终端模拟器的PC。到目前为止还不错。然后我从同一个地方下载了Android源代码“MLDP.v3.2-AndroidStudio.zip”。我把这个加载到Android SDK并让它运行。这显然是APP中包含的一个不同版本的APP。源代码看起来像后来的版本,编号为3.2版本。问题是,我无法让3.2版本以mldp模式接收数据。它连接OK和发送OK,但不会显示从PC发送的任何字符。我不知道这是安装问题还是代码错误。我相信我的硬件设置可以,因为我可以使用terminal8.apk进行双向通信,源代码还有其他版本吗,或者还有其他人正在运行3.2版本。CTTA
以上来自于百度翻译 以下为原文 Hi I have been using the MLDP mode of the RN4020 on a couple of projects with some success. I am now looking at developing a simple android app to connect to the RN4020 to send an recieive small blocks of data using MLDP. In order to get a head start on the project, I have downloaded MLDPTErminal8.apk from the microchip web site. This works OK with a phone, I can sent and receive data from my RN4020 module connected to a PC running a terminal emulator. So far so good. I then downloaded the android source code 'MLDPTerminal v3.2-AndroidStudio.zip' from the same place. I loaded this in the android SDK and got it running. This is clearly a different version of the app to the one contained in the apk. The source code looks like a later version and is numbered version 3.2 The problem is, I cant get the version 3.2 to recieve data in mldp mode. It connects OK and transmits OK, but wont display any chars sent from the PC. I don't know if this is a problem with my setup or a bug in the code. I am confident my hardware setup is OK because I can communicate both ways using terminal8.apk Are there any other versions of the source code out there, or has anyone else got version 3.2 runnng. I really just want to inspect the working code to give me some idea of what will be required in my project tiA |
1个回答
回答我自己的问题。原来,我使用的RN4020模块有修正1.10固件在船上。我最终在onServicesDiscovered(BluetoothGatt gatt,int status)例程中发现了一个注释掉的部分,它引用了低于1.20的固件。
以上来自于百度翻译 以下为原文 To answer my own post. It turns out the RN4020 module I was using had revision 1.10 firmware on board. I eventually found a section in the onServicesDiscovered(BluetoothGatt gatt, int status) routine that had been commented out which referred to firmware below 1.20. Replacing the module with a later version sorted the problem. |
只有小组成员才能发言,加入小组>>
4824 浏览 9 评论
1829 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2954 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
460浏览 1评论
1110浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
362浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1796浏览 0评论
GMT+8, 2024-4-24 04:45 , Processed in 1.201702 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
