嗨,在Keeloq系统中,我打算使用多个发射机。对于我的解码器,我可以使用HCS500,最多有7个发射机。如果我想使用更多,我可以使用PIC。-所有PIC C都能实现Keeloq吗?-解码器的数量有限制吗?我需要提供两个发射机与接收机,但我需要更换丢失/损坏的发射机。我想这样做,没有现场操作。我能直接在EEPROM中配对设备,而不需要学习过程吗?柜台可以改过自新吗?在所有的安全方案中是否可能(名义上的和安全的?)感恩节
以上来自于百度翻译 以下为原文 Hi, On a system with Keeloq , I intend to use multiple transmitters. For my decoder, i can use HCS500, with up to 7 transmitters. If I want to use more, I can use a PIC. - Can all PIC µC implement Keeloq? - Is there a limitation in the number of decoders? I need to supply 2 transmitters with the receiver, but I need to replace lost/broken transmitters. I want to do this without in-field operation. Can I pair devices directly within Eeprom, without learning process? Can the counter be overriden? Is this possible in all security schemes (Nominal and secure?) Thanks BR |
2个回答
几乎所有的,是的。KeeLoq不需要任何特殊的硬件,所以内存是唯一的限制。然而,系统中多个有源接收机之间的同步计数器的管理是困难的。配对发生在接收机侧——接收机确定发射机何时有效。如果能够访问接收器EEPROM,则可以直接更改内存,就像配对过程已经完成一样。当然,存储在EEPROM上的数据对于安全性很重要,应该受到保护。没有标准或典型的方法来重写同步计数器。计数器对系统的安全性至关重要,典型的实现会竭尽全力保护它。然而,KeeLoq最终还是一个软件解决方案,作为设计人员,您可以修改任何您想要的东西。必须注意不降低系统的安全性。
以上来自于百度翻译 以下为原文 Almost all, yes. KeeLoq does not require any special hardware so memory is the only limitation. Technically, there is no restriction. However, management of the synchronization counter between multiple, active receivers in a system is difficult. The pairing happens on the receiver side --- the receiver determines when a transmitter is valid. If you have access to the receiver EEPROM, it is possible to directly change memory as if the pairing process had been completed. Of course, data stored on the EEPROM is important for security and should be protected. There is no standard or typical way to override the synchronization counter. The counter is critical to the security of the system and typical implementations go to lengths to protect it. However, KeeLoq is ultimately a software solution and as a designer you can modify anything you wish. Care must be taken to not reduce the security of the system. |
我可以通过外部程序员BePROG+读取HCS300吗??
以上来自于百度翻译 以下为原文 micaels can i read hcs300 via external programmer beeprog+?? |
只有小组成员才能发言,加入小组>>
4778 浏览 9 评论
1814 浏览 8 评论
1733 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2941 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2043 浏览 5 评论
419浏览 1评论
1100浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
344浏览 0评论
253浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1751浏览 0评论
GMT+8, 2024-3-29 01:16 , Processed in 0.949286 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
