我已经卸载了一个老版本的MPLABX和XC32 1.40。接下来,我在Windows 8.1上安装了MPLABX IDE 3.51和XC 1.42。但是MPLABX仍然指向前一个编译器的位置。这个位置可以在什么地方更改/设置吗?谢谢你
以上来自于百度翻译 以下为原文 I have uninstalled an older version of MPLABX and xc32 1.40. Next I installed MPLABX IDE 3.51 and xc 1.42 on Windows 8.1. But MPLABX is still pointing to the location of the previous compiler. "C:Program Files (x86)Microchipxc32v1.40binxc32-gcc.exe"... Can this be changed/set somewhere? Thanks Guenther |
4个回答
[1]最好不要立即卸载旧版本。您可以同时安装多个IDE和编译器。项目文件会记住每个项目使用的是哪个版本,所以您不必为每个项目使用最新的compler。[2]您究竟在什么地方查看旧路径?那是什么时候显示的?
以上来自于百度翻译 以下为原文 [1] It's advisable to NOT uninstall old versoins immediately. You can have multiple IDE's and compilers all installed at the same time. The project file rememberds WHICH version was used for each project, so you are not forced to used the latest compler for every project. [2] What exactly are you doing to see the old path somewhere? i.e. WHEN is that displayed? |
我们可以假设您在MPLABX项目设置中更改编译器吗?
以上来自于百度翻译 以下为原文 Can we assume you change the compiler in the MPlabX project settings? |
我对此表示怀疑。我认为,他们假设它只使用安装了什么编译器,并没有意识到它确实记得以前使用的是哪个编译器。
以上来自于百度翻译 以下为原文 I doubt it. I think they assumed it would just use whatever compiler was installed, not realising that it DOES remember which compiler it was using previously. |
作为附带的/相关的问题,我的MPLABX找不到可能早些时候安装的用于MPLAB 8的XC16。昨天我重新安装了它,MPLABX仍然看不到它:让它显示什么诀窍?(类似于XC8……)
以上来自于百度翻译 以下为原文 As a side/related issue, my MPLABX can't find XC16 that was installed possibly earlier for use with MPLAB 8. Yesterday I reinstalled it, and still MPLABX won't see it: what is the trick to let it show? (something like it was with XC8...) |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-19 11:35 , Processed in 1.063612 second(s), Total 75, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
