我试图使用液晶显示功能(LCDInit();LCDClear();等等),我认为这些功能应该可以从微芯片获得。我选择include
以上来自于百度翻译 以下为原文 I'm trying to use lcd functions (LCDInit(); LCDClear(); etc.) which I think should be available from Microchip. I have #include Apparently I shouldn't need them and should use the code configurator, but that doesn't use the PIC18F6723 I'm using. Always so bloody hard to do anything with Microchip! |
3个回答
为什么?如果你正在考虑XLCD库,那么是的,这是旧的外围库的一部分。如果你的硬件连接不匹配这个例子,它们会有点疼。YUP,他们只给MCC增加了新设备,他们对旧设备不感兴趣。我的经验是T。无论如何,微型芯片库都是垃圾。也许看看他们的想法来源,只写你自己的。
以上来自于百度翻译 以下为原文 Why? If you are thinking of the XLCD library, then yes, that is part of the old peripheral libraries. They are a bit of a pain to use if your hardware connections don't exactly match the example. Yup, they are only adding new devices to MCC, they're not interested in pushing old devices. My experience is that Microchip libraries are rubbish anyway. Maybe look at their source for ideas, and just write your own. |
它们不是。你必须在项目中包含一个LCD库文件。试试这个用Microchip PicDEM 2加上魔星板源代码的LCD库。下载库文件并将其包含到项目中。如果要使用旧的外围库,则必须单独下载并将其安装到编译器中。从XC8 V1.35,这个图书馆不再包括在内。
以上来自于百度翻译 以下为原文 They ara not. You must include an LCD library file into your project. Try this LCD library supplied with Microchip PICDEM 2 Plus demonstartion board source code. Download the library file and include it into your project. If you want to use the old peripheral library, you'll have to download it separately and install it into your compiler. From XC8 v1.35, this library is no longer included. |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-19 17:16 , Processed in 1.186327 second(s), Total 70, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
