你好!我正在使用STEVAL-IHM039V1和STEVAL-IHM027V1构建电机控制器。我收到了这些主板,为我的设置配置了固件(FOC SDK 3.4)和硬件设置(三分频pmsm w /霍尔传感器),并使用JTAG连接器,ARM-USB-tiNY-H编程器/调试器刷新代码和gdb / OpenOCD。 LCD接口工作等。
但是,一旦我刷了代码,我就再也无法通过OpenOCD连接到主板了。它说它无法检测到电路板。但是,如果我在连接时按住重置按钮,我可以连接到它并重新刷新它。这让我觉得固件中的某些引脚设置可能不正确,这会使JTAG不起作用。有任何想法吗? 以下是尝试连接的OpenOCD的输出: #foc-sdk#f4xx#motor-control 以上来自于谷歌翻译 以下为原文 Hello! I'm building a motor controller using the STEVAL-IHM039V1 and the STEVAL-IHM027V1. I received these boards, configured the firmware (FOC SDK 3.4) and hardware settings for my setup (three-shunt pmsm w/ hall sensors), and flashed the code using the JTAG connector, an ARM-USB-TINY-H programmer/debugger, and gdb/OpenOCD. The LCD interface works and so on. However, once I flashed the code, I can no longer connect to the board through OpenOCD. It says that it can't detect the board. However, I can connect to it and reflash it if I hold down the reset button while connecting. This makes me think that some pin setting might be incorrect in the firmware that somehow makes the JTAG not work. Any ideas? Here is the output of OpenOCD trying to connect:
#foc-sdk #f4xx #motor-control |
1个回答
Ciao martirosyan.hayk
我可以假设,对于错误的配置,JTAG的某个引脚已重新映射为另一个功能。对于STEVAL-IHM039V1来说,这不是一个好消息。另一件事可能是错误的时钟设置。 在这里发布您的工作台项目,以便我们检查。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao martirosyan.hayk What I can suppose is that for a wrong configuration some pin of the JTAG has been remapped for another function. This is not usal for the STEVAL-IHM039V1. Another thing can be a wrong clock setting. Post here your workbench project so we can check. Ciao Gigi |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1431 浏览 1 评论
2099 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1509 浏览 1 评论
2818 浏览 6 评论
5227 浏览 21 评论
351浏览 4评论
526浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
596浏览 3评论
494浏览 3评论
GMT+8, 2024-4-23 14:19 , Processed in 0.806646 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
