你好,我想用PIC32芯片设计一个音频效果单元,并开始寻找一个好的DEV板。电路板需要立体声音频输入和输出,并具有一个SOIC/SSOP封装的芯片,因为QFN会给PCB设计增加不必要的复杂性。最好是有相当数量的RAM,虽然这是可协商的。如果有符合这些要求的话,请告诉我。谢谢!
以上来自于百度翻译 以下为原文 Hi, I want to use the PIC32 chips in the design of an audio effects unit and was looking for a good dev board to start with. Board needs stereo audio input and output and feature a chip that comes in a SOIC/SSOP package, since QFN would add unnecessary complexity to the PCB design. Also preferably something with a fair amount of RAM, though this is negotiable. Please let me know if there is something that matches these requirements. Thanks! |
9个回答
TQFP会更容易,它们都有相当数量的RAM。我从来没有见过不公平的RAM的照片。
以上来自于百度翻译 以下为原文 TQFP would be easier. They all have a fair amount of RAM. I've never seen a PIC with unfair amount of RAM. |
好的,让它扩展到包括TQFP,并阐明RAM最好是gt=128kb。有什么可以推荐的吗?
以上来自于百度翻译 以下为原文 Alright, lets extend it to include TQFP and clarify that RAM is preferably >=128kB. Is there anything you can recommend? |
嗨,Mikro Elektronika有一个开发板与PIC32 MX460,与音频编解码器VS1053与耳机输出和其他几个外设在船上。HTTPS://Suff.Mikro.COM/SMART-DISPLAs/MikROMIDEA/MIKROMETROMA3/PIC32 MX4板配备引导程序和演示软件的编译器和溴化锂。来自同一公司的白羊座,我也可以与MPLAB X和Microchip编译器一起使用。有6引脚ICSP连接器的脚印在板上拾取3。注意,在这种类型的板上,ICSP连接器上的标记可能是混淆的,丝网上的信号名称是正确的,但是PIN 1标记可能在WR上。再见,问候,Mysil
以上来自于百度翻译 以下为原文 Hi, Mikro Elektronika have a development board with PIC32MX460, with a audio codec VS1053 with headphone output and several other peripherals on the board. https://shop.mikroe.com/smart-displays/mikromedia/mikromedia-3/pic32mx4 The board comes with a bootloader and demo software for compilers and libraries from the same company, I may also be used with MPLAB X and Microchip Compiler. There is footprint for 6 pin ICSP connector to PICkit 3 on the board. Note, that on this type board, markings on ICSP connector may be confusing, signal names on silkscreen is correct, but pin 1 marker may be on the wrong end. Regards, Mysil |
嗨,编解码器有音频输入,但在该板上没有连接。MikROMeRO+板在EdG.HTPSP//Suff.MikROE.COM/SMART-DISPLASS/MIKROMETIAA/MICROMETIA4/PIC32 MX7上有2个音频线输入和2个线输出。编解码器在这里:HTTP://www. vLsi.Fi/En/Studis/VS1。MysIL语言
以上来自于百度翻译 以下为原文 Hi, The codec have audio inputs, but on that board they have no connection. Mikromedia+ board have 2 audio line inputs and 2 line outputs in connector footprint along the edge. https://shop.mikroe.com/smart-displays/mikromedia/mikromedia-4/pic32mx7 The Codec is here: http://www.vlsi.fi/en/products/vs1053.html Mysil |
您好,如果您只是原型,包可能对您不重要。这将是你的决定。我们可以推荐的是PIC32蓝牙音频开发工具包(DV3200 32)。该板具有PIC32 MX470设备与512K闪存和128K SRAM。它是模块化的,使PIM板,使处理器可以改变到其他家庭。我们有几个这样的PIM板可用。在音频编解码器方面,这些也是模块化的。音频有2种可能的I/O路径(虽然所购买的板只有1个)。我们有一个音频编解码器与线输入使用AK464 2(AC320100)。注意,可以同时将2个板放在工具包上。在MPLAB和谐中有应用实例和编解码器的驱动程序。
以上来自于百度翻译 以下为原文 Hello, If you are just prototyping, the package may not be critical to you. That will be for you to decide. A board we might recommend for this is the PIC32 Bluetooth Audio Development Kit (DV320032). This board features a PIC32MX470 Device with 512K Flash and 128K SRAM. It is modular and enables a PIM board so the processor can be changed to other families. We have several such PIM boards available. In terms of the audio codec, these are also modular. There are 2 possible I/O paths for audio (although the board as purchased has only 1). We have an audio codec with a line input using the AK4642 (AC320100). Note it is possible to put 2 of these boards onto the kit at the same time. There are applications examples and drivers for the codec in MPLAB Harmony. |
嘿,我可能已经找到了一个:我正在看使用D3311音频开发板(HTTP://www. MyCHIP.COM/DeavigoToSs/PositDeLiel.ASPX)PICNNO=D3311)用于PIC32 MX795F512L(http://www. McCyc.com /wwwsFu/En/En545 660)。如果我有PIC32的GPIO引脚,这个DEV板对于我的应用来说是完美的。如果他们没有联系,董事会将不适合我的目的。对于D3311(HTTP://WW1.Microchip .com/下载/ En/DeVicoDC/AbB%20%20PIC32 %20%%Guest.pdf)的用户指南,对于它们是如何连接的不太清楚,我希望通过扩展连接器或类似的东西可以访问它们。是这样吗?买之前一定要知道。
以上来自于百度翻译 以下为原文 Hey I actually might have found one: I was looking at using the DM320011 audio development board (http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=DM320011) for PIC32MX795F512L (http://www.microchip.com/wwwproducts/en/en545660). This dev board is perfect for my application if I have access to the PIC32's GPIO pins. If they are left unconnected the board will not suit my purposes. The user guide for the DM320011 (http://ww1.microchip.com/downloads/en/DeviceDoc/ADB%20for%20PIC32%20User%20Guide.pdf) isn't overly clear about how they are connected, if at all. My hope is that I can access them via the expansion connectors, or something similar. Is this the case? Need to know for certain before buying. |
这个板是否包括对PIC的GPIO引脚的访问?如果我能访问模拟和GPIO输入,那么这正是我所需要的。
以上来自于百度翻译 以下为原文 Does this board include access to the GPIO pins of the PIC? If I can access the analog and gpio inputs then this is exactly what I need. |
事实上,好奇心PICMX470 DEV板(HTTP://www. McCHIP.COM/DeavigoToSs/PositDeLiel.ASPX)?PARDNO=DM320103)似乎它有我需要的功能,而不让我支付一堆我不喜欢的东西,比如蓝牙和LCD屏幕。它说TAK462(AC320100)是兼容的,而未使用的GPIO引脚可以通过一个头来访问。这里的数据表有点混乱,这是否意味着所有GPIO引脚都将只能访问或仅使用其中之一?
以上来自于百度翻译 以下为原文 Actually the Curiosity PICMX470 Dev Board (http://www.microchip.com/developmenttools/productdetails.aspx?partno=dm320103) seems like it has the functionality I need without making me pay for a bunch that I don't, like bluetooth and an lcd screen. It says the AK4642 (AC320100) is compatible, and that unused GPIO pins are accessible through a header. The datasheet is kind of muddled here though, does that mean all GPIO pins will accessible or only some of them? |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1748 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2955 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1800浏览 0评论
GMT+8, 2024-4-25 20:52 , Processed in 1.180548 second(s), Total 83, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
