问候语!我需要多一点的计算能力,所以我想在200兆赫的USPIC32 MZ1024ECG064(TQFP 64包)。在这个速度下我会有任何热问题吗?我有经验的DSPIC30F5015,它开始产生大量的热量在120兆赫。这里也一样吗?我必须在这个芯片上安装散热片吗?谢谢!
以上来自于百度翻译 以下为原文 Greetings! I need little bit more calculation power, so I want to use PIC32MZ1024ECG064 (TQFP 64 package) at 200MHz. Am I going to have any heat problems at this speed? I have experience with dsPIC30F5015 and it starts to generate a lot of heat at 120MHz. Is it here the same? Do I have to put a heatsink on this chip? Thanks! |
6个回答
VDD=3.3 V。从数据表(表37.6)IDDYMAX=130MAPdjax=429 MWTJA=49 DEGC/W为TQFP包(表32-3)DeltAT=PDMax×TJA=429 MW* 49 DGC/W=21 DEGCTJYOPATATION×MAX=DeltAT+TMIMPTENXMAX=21 DEGC+85 DEGC=106 DEGC& LT;TJYRATEDIX MAX=125DEGCIT显示,您从额定最大结温到最坏情况工作结温度大约有20的DEGC裕度(最坏情况)。根据你自己的降级可靠性准则,这可能是可以的。
以上来自于百度翻译 以下为原文 All numbers approximate. Assume Vdd = 3.3 V. From data sheet (Table 37-6) Idd_max = 130mA Pd_max = 429 mW Tja = 49 degC/W for TQFP package (from Table 37-3) DeltaT = Pd_max * Tja = 429 mW * 49 degC/W = 21 degC Tj_operating_max = DeltaT + Tambient_max = 21 degC + 85 degC = 106 degC < Tj_rated_max = 125 degC It appears you have about a 20 degC margin (worst case) from rated maximum junction temperature to worst case operating junction temperature. Depending on your own derating guidelines for reliability, this is probably OK. |
谢谢!DSPIC在5V上运行,它的功率增加到1W,最大工作电压达到124V,但是在3.3上一切都可以。谢谢!
以上来自于百度翻译 以下为原文 Thanks! The dsPIC was running on 5V and it increases the power to 1W and operation max to 124V. But here on 3.3 everything should be OK. Thanks! |
嗨,我不认为任何PIC需要散热片…即使是古老的DSPIC30。我记得他们可以很热,但仍然在包耗散特性方面。
以上来自于百度翻译 以下为原文 Hi, I don't think any PIC needs heatsink...even the venerable dsPIC30. I remember they could get really hot but still within the package dissipation characteristics Regards |
不要使用心电图,使用EFG。心电图是错误的,不推荐使用。附图是在192MHz运行的PIC32 MZ1024EFG064的热像图。
以上来自于百度翻译 以下为原文 Don't use the ECG, use the EFG. The ECG is bug-ridden and not recommended. Attached is a thermograph of a PIC32MZ1024EFG064 running at 192MHz. Attached Image(s) |
只有40度,还是它能显示的那么高?:)
以上来自于百度翻译 以下为原文 Only 40 degrees, or is that as high as it can show? :) |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-19 22:05 , Processed in 1.021083 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
