你好,
我是FPGA的初学者。 我正在使用Artix-7的Nexys DDR4,我想向FPGA输入数字信号。 然后我想知道如何实现这一点。 我可以使用pmod端口(例如JA,JB等)来获取数字信号输入吗? 如果pmod端口可用,我想知道I / O标准和Vcc和GND端口的使用等设置。 非常感激, tobitobi 以上来自于谷歌翻译 以下为原文 Hello, I'm a FPGA beginner. I'm using Nexys DDR4 of Artix-7, and I'd like to input a digital signal to FPGA. Then I'd like to know how I can realize that. Can I use the pmod ports(such as JA, JB etc..) for acquisition of digital signal inputs? If pmod ports are available for it, I'd like to know the setting such as I/O standard and usage of Vcc and GND ports. Much appreciated, tobitobi |
10个回答
@tobitobi你能把我们链接到ADC页面/数据表吗?
假设您使用的ADC类似于MCP3208(8通道,12位,100ksps),那么Pmod端口就可以了。 MCP3208可以执行1Mbps SPI,这很容易在Pmod功能范围内。 SPI在FPGA上特别容易; 它基本上只是一个时钟和一个移位寄存器。 如果你超过50Mbps,那么Pmod可能会成为一个挑战,但50Mbps SPI非常罕见 - 特别是对于相对较慢的ADC。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @tobitobi Can you link us to the ADC page/datasheet? Assuming the ADC you're using is something like the MCP3208 (8-channel, 12-bit, 100ksps) then a Pmod port will be fine. the MCP3208 can do 1Mbps SPI, which is easily within the Pmod capabilities. SPI is especially easy on an FPGA; it's basically just a clock and a shift register. If you go over about 50Mbps then Pmod might become a challenge, but 50Mbps SPI is pretty rare - especially for a relatively slow ADC. View solution in original post |
@tobitobi
您还能告诉我们有关此数字信号的更多信息吗? 它是一个非常低速的信号(例如人类按下开关),还是中速信号(例如SPI总线),还是高速信号(例如HDMI)? 是推挽(例如SPI),漏极开路(例如I2C,开关取决于布局)还是差分(HDMI)? Pmod端口适用于中低速信号(它们不是真正用于处理高速信号)。 每个引脚提供3.3V和GND引脚,I / O为3.3V(不耐5V - 从Arduino或AVR施加5V会损坏FPGA)。 对于大多数通用I / O,LVCMOS33 I / O标准可能是一个不错的选择(因为您可能不太关心精确的电压阈值)。 以上来自于谷歌翻译 以下为原文 @tobitobi What more can you tell us about this digital signal? Is it a very low-speed signal (eg. a human pressing a switch), or a medium-speed one (eg. an SPI bus), or a high-speed one (eg. HDMI)? Is it push-pull (eg. SPI), open-drain (eg. I2C, switches depending on layout), or differential (HDMI)? The Pmod ports are fine for low to medium speed signals (they're not really built to handle high-speed). Each one provides 3.3V and GND pins, and the I/O is 3.3V (it is not 5V tolerant - applying 5V from an Arduino or an AVR will damage the FPGA). For most general-purpose I/O, the LVCMOS33 I/O standard is likely to be a good bet (since you probably don't care too much about exact voltage thresholds). |
@ u4223374
谢谢你的回复。 我想连接外部ADC(串行通信)和精确转换的数据。 ADC的采样速度为100ksps。 它对pmod端口来说太快了吗? 我想要比4更多的模拟数据,所以我不认为Nexys4 DDR中包含的XADC对它有好处。 如果pmod端口不好,你认为我怎么能用外部ADC获得几个模拟数据? 非常感激, tobibobo 以上来自于谷歌翻译 以下为原文 @u4223374 Thank you for replying. I want to attach external ADCs(serial communication) and acquisite converted data. The sampling speed of ADC is 100ksps. Is it too fast for pmod ports? I want to acquisite more analog data than 4, so I don't think XADC which is included in Nexys4 DDR is good for it. If pmod ports is bad for it, how do you think I can get several analog data with the external ADC? much appreciated, tobibobo |
嘿tobibobo,
ADC的采样速度为100ksps。 它对pmod端口来说太快了吗? 100ksps意味着介于0.8和2Mbit / s之间,这对于PMOD接口来说没有问题。 最好, 赫伯特 --------------是的,我这样做是为了好玩! 以上来自于谷歌翻译 以下为原文 Hey tobibobo, The sampling speed of ADC is 100ksps. Is it too fast for pmod ports? 100ksps means between 0.8 and 2Mbit/s which is no problem for the PMOD interface. Best, Herbert -------------- Yes, I do this for fun! |
@ u4223374
确切地说,ADC是MCP3208。 如果您不介意的话,我希望您告诉我们有关XADC采样速度能力的链接。 非常感激, tobibobo 以上来自于谷歌翻译 以下为原文 @u4223374 exactly the ADC is MCP3208. I'd like you to tell me the link about the sampling speed capability of XADC, if you don't mind. much appreciated, tobibobo |
@tobitobi关于MCP3208的幸运猜测!
如上所述,它在Pmod端口上绝对没问题,并且它的接口非常简单,只需FPGA。 XADC的关键文件是UG480。 采样率最大为1MSPS。 以上来自于谷歌翻译 以下为原文 @tobitobi Lucky guess about the MCP3208! As above, it'll be absolutely fine on a Pmod port, and its interface is extremely simple with an FPGA. The key document for the XADC is UG480. Sampling rate is 1MSPS maximum. |
@ u4223374
谢谢,但我想检查一下pmod端口的频率能力。 因为我想将数字数据输入到pmod端口。 非常感激, tobibobo 以上来自于谷歌翻译 以下为原文 @u4223374 Thank you, but I want to check the frequency capability of pmod ports. Because I want to input the digital data to pmod ports. much appreciated, tobibobo |
没有真正的Pmod功能文档 - 它只取决于Digilent如何设计电路板。
然而,假设他们没有对高速进行任何优化,50MHz通常是相当安全的赌注。 Digilent销售他们声称可以做到16Mbps的Pmod,所以Zybo很容易忍受这个速度(远远快于MCP3208所需要的速度)。 以上来自于谷歌翻译 以下为原文 There's not really a document for the Pmod capabilities - it just depends on how Digilent has designed the board. However, 50MHz is normally a fairly safe bet on the assumption that they haven't done any optimization for high speed. Digilent sells a Pmod that they claim can do 16Mbps, so it'd be a good bet that the Zybo can easily tolerate that speed (far faster than the MCP3208 will need). |
嘿tobibobo,
我成功地使用Zedboard上的PMOD端口输出720p HDMI,这需要~750MHz的数据速率,因此PMOD端口本身不会成为您用例的限制因素。 希望这澄清, 赫伯特 --------------是的,我这样做是为了好玩! 以上来自于谷歌翻译 以下为原文 Hey tobibobo, I successfully used the PMOD ports on a Zedboard to output 720p HDMI, which requires a data rate of ~750MHz, so the PMOD port itself will not be a limiting factor for your usecase. Hope this clarifies, Herbert -------------- Yes, I do this for fun! |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2606 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2079 浏览 9 评论
3151 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2196 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
425浏览 1评论
1526浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2178浏览 0评论
511浏览 0评论
1642浏览 0评论
GMT+8, 2024-4-25 22:40 , Processed in 1.044417 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
