我正在运行Linux Mint 17.1 64位。
每当我想在块设计中看到某些IP的文档并单击“产品指南”时,终端中将显示此错误,并且不会打开任何内容: QLocalSocket :: connectToServer:连接被拒绝 如果我手动打开DocNav然后尝试在其中打开一些文档 (进程:32366):GLib-CRItiCAL **:g_slice_set_config:断言'sys_page_size == 0'失败 (firefox:32366):GLib-GObject-WARNING **:在初始化类后尝试添加属性GnomeProgram :: sm-connect (firefox:32366):GLib-GObject-WARNING **:在初始化类后尝试添加属性GnomeProgram :: show-crash-dialog (firefox:32366):GLib-GObject-WARNING **:在初始化类后尝试添加属性GnomeProgram :: display (firefox:32366):GLib-GObject-WARNING **:在初始化类后尝试添加属性GnomeProgram :: default-icon 并且它说Firefox已经在运行,所以为了让thar工作,我需要关闭所有Firefox窗口,这是不可接受的。 我已经尝试过这个我在某个地方看到的解决方案但是没有起作用: cd /opt/Xilinx/SDK/2013.4/lib/lin64 sudo mv libstdc ++。so.6 libstdc ++。so.6.orig 它没有用。 有人能帮我吗? 以上来自于谷歌翻译 以下为原文 I'm running on Linux Mint 17.1 64-bits. Whenever i want to see the documentation of some IP in the block design and click in "Product Guide", this error appears in the terminal and nothing opens: QLocalSocket::connectToServer: Connection refusedIf I open DocNav manually and then try to open some document within it (process:32366): GLib-CRITICAL **: g_slice_set_config: assertion 'sys_page_size == 0' failed(firefox:32366): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised(firefox:32366): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised(firefox:32366): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised(firefox:32366): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised and it says that Firefox is already running, so in order for thar to work I need to close all the Firefox windows, which is not acceptable. I already tried this solution that I saw somewhere but that didn't function: cd /opt/Xilinx/SDK/2013.4/lib/lin64sudo mv libstdc++.so.6 libstdc++.so.6.orig And it didn't work. Can someone help me? |
9个回答
你好,你能在firefox浏览器关闭时打开DocNav吗?谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello, Are you able to open DocNav when firefox browser was closed? Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
从Vivado打开它?
没有。 我总是可以手动打开它,但是当我关闭firefox时我只能在其中打开链接 以上来自于谷歌翻译 以下为原文 Open it from Vivado? No. I can always open it manually but I can only open links within it when I have firefox closed |
你好,你有代理设置吗?如果是,设置为环境变量“http_proxy”的值是多少?谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello, Do you have proxy settings? If yes, what is the value set to environmental variable "http_proxy"? Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
对不起,但是什么是代理设置,如何检查是否设置了它们。
以上来自于谷歌翻译 以下为原文 I'm sorry but what are proxy settings and how do I check if I have them set up. |
你好@jmales
要检查您是否有代理设置,请按以下步骤操作: 1.打开Firefox浏览器 2.单击“选项”菜单 3.选择“高级”选项卡 4.单击网络选项卡 - >设置 - >,弹出一个包含代理设置的窗口。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @jmales To check whether you have proxy settings, follow below steps: 1. Open Firefox browser 2. Click on Options menu 3. Select the Advance Tab 4. Click on Network Tab --> Settings --> and a window pops up with proxy settings. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
Ty为@vuppala的答案。
当我这样做时,它显示设置是“使用系统代理设置” 以上来自于谷歌翻译 以下为原文 Ty for the answer @vuppala . When I do that it shows that the settings are to "Use system proxy settings" |
好吧,我亲爱的伙伴,我想你忘了复制一个新的libstdc ++。so.6
例如,我使用Vivado遇到了同样的问题。 Vivado(或者系统实际上......无所谓)报告错误为我提供了比SDK更多的信息: - 我得到了一些旧版本的libstdc ++。so.6(mising GLIBCXX_3.4.15) - 关于这个旧lib的路径 所以我做了什么: 找到--rexep libstdc ++ 。so .6 $> strings.in geany strings.in& 然后我添加在文件的顶部 #!/ bin / sh -x 用于脚本调试输出 geany有一些整齐的块编辑功能,所以我补充说 字符串 开始每一行和 | grep GLIBCXX_3.4.15 到每一行结束 然后 chmod 777 strings.in 和 ./strings.in 这将为您找到一个合适的libstdc ++。so.6 所以最后在我的例子中我必须这样做: sudo cp /opt/Xilinx/.xinstall/Vivado_2014.4/lib/lnx64.o/libstdc++.so.6 /opt/Xilinx/Vivado/2014.4/ids_lite/ISE/lib/lin64/libstdc++.so.6 我不得不sudo Firefox最初还是很糟糕,但到目前为止,第二次运行和所有subsecuent都可以。 以上来自于谷歌翻译 以下为原文 Well jmales my dear mate I think you forgot to copy a new libstdc++.so.6 For instance I got the same problem using Vivado. Vivado (or maybe the system actually... does not matter) reports that error providing me with some more info than SDK: - that I got some old version of libstdc++.so.6 (mising GLIBCXX_3.4.15) - an about the path of this old lib So what I did: locate --rexep libstdc++.so.6$ > strings.ingeany strings.in &then I added at the top of the file #!/bin/sh -xfor script debug output geany has some neat block editing capabilites so I added strings to begining of every line and | grep GLIBCXX_3.4.15to every line end then chmod 777 strings.inand ./strings.inThis shall locate an adecuate libstdc++.so.6 for you So in the end in my example I had to do: sudo cp /opt/Xilinx/.xinstall/Vivado_2014.4/lib/lnx64.o/libstdc++.so.6 /opt/Xilinx/Vivado/2014.4/ids_lite/ISE/lib/lin64/libstdc++.so.6I had to sudo Firefox intially chrashed, but the second run and all subsecuent are OK so far for me. |
忘记提到我还将libstdc ++。so.6保存到libstdc ++。so.6.orig
有时我必须点击产品指南或产品网页两次(因为拒绝连接) - 所以它有点片状但有效 以上来自于谷歌翻译 以下为原文 Forgot to mention that I also saved the libstdc++.so.6 to libstdc++.so.6.orig Some times I have to click on the Product Guide or Product Webpage twice (becouse of connection refused) - so it is a little bit flaky but works |
tomasz.janicki.tjthanks,这对我来说就像一个魅力(Linux Mint 17,Vivado 2015.3)。
STE 以上来自于谷歌翻译 以下为原文 tomasz.janicki.tj thanks, this worked like a charm for me (Linux Mint 17, Vivado 2015.3). Ste |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2606 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2079 浏览 9 评论
3151 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2196 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
425浏览 1评论
1526浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2178浏览 0评论
511浏览 0评论
1642浏览 0评论
GMT+8, 2024-4-25 17:38 , Processed in 0.991026 second(s), Total 53, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
